WNYPCRepair 1,924 #1 Posted September 20, 2016 A cross between a Johnny Bucket and a loaderhttp://www.grit.com/tools/machinery/tractors/mini-front-end-loader-zm0z16sozreg.aspx 3 Share this post Link to post Share on other sites
mmmmmdonuts 274 #3 Posted September 20, 2016 Interesting. I would just worry about tipping over and frame stressing since it just hangs off the front end. By being able to lift it 54" high I think quite a bit of problems could happen with very little weight at all due to center of gravity. Share this post Link to post Share on other sites
953 nut 65,349 #4 Posted September 20, 2016 Any garden tractor with a heavy load in a bucket lifted high is unstable; I have loaded tires, 130 pounds of wheel weights and a 200 pound weight box for a Johnson Workhorse FEL on my GT-14 and you don't want to turn it or be on a side hill with the loaded bucket more than a few inches off the ground. 3 Share this post Link to post Share on other sites
WNYPCRepair 1,924 #5 Posted September 20, 2016 Yes, I agree, it would be rough on the tractor, and unstable if very high, but if you used it more like a Johnny Bucket until you needed to dump, it is a good idea. I think I would still make a subframe to spread the load back to the rear axles. 3 Share this post Link to post Share on other sites
Forest Road 595 #6 Posted September 26, 2016 Don't see how that could ever have enough balast to keep the rear tires on the ground 1 Share this post Link to post Share on other sites
rexman72 210 #7 Posted September 26, 2016 i think those are going for 1700 which counts me out. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #8 Posted September 27, 2016 (edited) On September 25, 2016 at 9:18 PM, Forest Road said: Don't see how that could ever have enough balast to keep the rear tires on the ground I agree. Putting the mount in front of the front axle just makes it a see saw. After looking closer at it, it really doesn't make sense. It's an interesting concept, but you really aren't saving much steel. I also wonder if the reservoir is in the uprights. Just read it again, uses onboard hydraulics. Edited September 27, 2016 by WNYPCRepair Share this post Link to post Share on other sites
