murph 5 #1 Posted September 16, 2016 I think I have a bad head gasket,found oil side of muffler seems to be blowing out side KOHLER MAG 14 spec 601559 sec #2228110723 any recommendations on gaskets and head torque Share this post Link to post Share on other sites
953 nut 62,108 #2 Posted September 17, 2016 I think you are correct about the head gasket. Napa should have it. Kohler Single Cylinder Engine Specs _ Torque Values and Sequences for Fasteners _ Identification & Torque Settings of Most Commonly Used Grades of Bolts (1) (1).html Be sure to check the head over carefully, place some adhesive backed sand paper on a sheet of glass and gently sand the head on it to check for flatness. Share this post Link to post Share on other sites
MalMac 1,333 #3 Posted September 17, 2016 Also you should not be getting so much oil up there that you are getting oil coming out the head. Could have broke oil ring or bad valve seats. 1 Share this post Link to post Share on other sites
murph 5 #4 Posted September 17, 2016 thanks for the help,gasket was bad,head bolts were hand tight,valves looked tired,new gasket,cleaned up,torqued down,run great THANKS A LOT,Murph 1 Share this post Link to post Share on other sites
