mcurran 37 #1 Posted September 15, 2016 looking for parts for a 5060 six speed transmission, wheel horse part # needle bearings, 1526, 1530, 1531. Brake drum 3902. any info would be appreciated. Share this post Link to post Share on other sites
Achto 31,061 #2 Posted September 16, 2016 Have you checked out Steve's cross reference chart under the transmission section? Share this post Link to post Share on other sites
Achto 31,061 #3 Posted September 16, 2016 13 hours ago, mcurran said: looking for parts for a 5060 six speed transmission, wheel horse part # needle bearings, 1526, 1530, 1531. These two pdf's will get you cross reference numbers. 2. UNI DRIVE TRANS 2.pdf 3. UNI DRIVE TRANS 3.pdf 2 Share this post Link to post Share on other sites
stevasaurus 23,618 #4 Posted September 16, 2016 (edited) Verify that the brake shaft is 1". I have a brake drum if you want. send me a PM. Those PDF's may be confusing, because they really do not do the #5060 transmission specifically. WH #1526 is also TORO #9416......it crosses to Koyo or Torrington #B1816 1 1/8" ID axle bearings WH #1530..........................................it crosses to Koyo or Torrington #B1612 1" ID brake shaft bearing WH #1531..........................................it crosses to Koyo or Torrington #M10121 3/4" ID cap bearing for end of spline shaft All of these bearings are available from Motion Industries, NAPA, Autozone and maybe even TORO. Edited September 16, 2016 by stevasaurus 1 Share this post Link to post Share on other sites
mcurran 37 #5 Posted September 19, 2016 On 9/15/2016 at 8:47 PM, achto said: Have you checked out Steve's cross reference chart under the transmission section? I am in the process of contacting him now. thanks On 9/16/2016 at 11:30 AM, stevasaurus said: Verify that the brake shaft is 1". I have a brake drum if you want. send me a PM. Those PDF's may be confusing, because they really do not do the #5060 transmission specifically. WH #1526 is also TORO #9416......it crosses to Koyo or Torrington #B1816 1 1/8" ID axle bearings WH #1530..........................................it crosses to Koyo or Torrington #B1612 1" ID brake shaft bearing WH #1531..........................................it crosses to Koyo or Torrington #M10121 3/4" ID cap bearing for end of spline shaft All of these bearings are available from Motion Industries, NAPA, Autozone and maybe even TORO. Thanks for helping out. My shaft is 3/4" with two flat sides, if you know what I mean for the brake drum. I ran in to someone saturday and he thought I could get them at napa. I'll let you know how i make out. Thanks again Share this post Link to post Share on other sites
stevasaurus 23,618 #6 Posted September 20, 2016 (edited) OK..not a problem, but something is not right. If you have a #5060 transmission, your brake shaft is 1". The #3902 brake drum has a 1" shaft hole and takes a #1530 bearing which has a 1" ID. If you have a 3/4" shaft...you do not have a #5060 transmission. Just sayin" Better figure it out before you start ordering parts. Edited September 20, 2016 by stevasaurus Share this post Link to post Share on other sites
