Jamie Kriha 1 #1 Posted September 15, 2016 I'm new to club I have a c160 automatic I'm having trouble with the hydrostatic when you want to go forward it doesn't want to move and then it will take off wide open.i also see that the plastic peace that to looks like it control's the forward and reverse motion is cracked and brittle.any idea 1 Share this post Link to post Share on other sites
Wishin4a416 2,191 #2 Posted September 15, 2016 Welcome to the forum. Im not up on the Hydro's but I am sure someone will be along to help. 1 Share this post Link to post Share on other sites
slammer302 2,156 #3 Posted September 15, 2016 I would say that ur linkage for the motion control needs sum maintenance. I would try to find a replacement for the cranking plastic piece. If it's the 5996 speed control cam thier is a new one on eBay for 18$ I think Share this post Link to post Share on other sites
Jamie Kriha 1 #4 Posted September 15, 2016 Thank you I will see if i can find it Share this post Link to post Share on other sites
pfrederi 18,639 #5 Posted September 15, 2016 They 5996 are still available form Toro and other parts places. You can see parts manual here http://www.wheelhorseforum.com/files/file/3515-tractor-1975-c-160-auto-iplpdf/ Owner manual and adjustment of speed control here http://www.wheelhorseforum.com/files/file/3514-tractor-1975-c-160-om-wiringpdf/ Share this post Link to post Share on other sites
daveoman1966 3,839 #7 Posted September 16, 2016 Aside from the 5996 cam you MAY have a issue with the tab weld at the end of the control linkage shaft. If broken, the shaft will move almost at random...independent of the motion control lever. You should also look for cracks in the frame plate where it bolts to the front of the transmission. If really bad, the tractor with flex at that point, allowing radical movement of the cam 5996. Share this post Link to post Share on other sites
