kudzu3 323 #1 Posted September 11, 2016 Okay, I've been wanting to ask this question for a long time, just too embarrassed, thinking it must be a really stupid one, and maybe I should know the answer. 1970 Raider 10, the ignition switch cranks the engine and stays all the way to the right, which is as it should be, but if I want to use the lights I have to turn it one click to the left. Is this normal? Why does the switch have two positions? 1 Share this post Link to post Share on other sites
953 nut 63,050 #2 Posted September 11, 2016 My GT-14 has the same type switch. To operate the electric PTO I have to turn it back one click; guess it is to make sure the lights aren't on and PTO is not engaged drawing current while starting the engine. Or it could be the lawyers had more pull than the engineers! 1 Share this post Link to post Share on other sites
russellmc301 601 #3 Posted September 11, 2016 Mine sayes runing and etc so i figured so you can have things hooked up and dont have them on then flip it and turn them on. Share this post Link to post Share on other sites
pfrederi 19,276 #4 Posted September 11, 2016 Yes the ignition switches had 4 postilions Off -- Run with lights, ---run with out lights-- and crank/start 1 Share this post Link to post Share on other sites
Ed Kennell 43,799 #5 Posted September 12, 2016 Yep, that's how my Raider works. Share this post Link to post Share on other sites
