MalMac 1,333 #1 Posted September 11, 2016 Was just curious as to whether the newer style cable control that is used to trip or pull the pin on the snow blade is any better than the old design of the hooked rods and pivot plate that has been a stable for years. I've never used one with a cable. To be honest, I've never had any trouble or complaints with the rod style. A drawback I could see with the cable style would be getting a froze cable inside its casing. Share this post Link to post Share on other sites
oldlineman 1,626 #2 Posted September 11, 2016 Thats what I thought frozen cable, I think if it aint broke don't fix it. Share this post Link to post Share on other sites
cleat 8,383 #3 Posted September 11, 2016 I sort of split the difference and went with open aircraft cable through guides and tubes. Cable is stainless steel so should be no problem with corrosion. 6 Share this post Link to post Share on other sites
oldlineman 1,626 #4 Posted September 11, 2016 Now Cleat that is a very good idea no freezing with that cable, mine has rod and never had any trouble with it, a little harder to install but that is why I have more than one tk I don't have to take it off. 1 Share this post Link to post Share on other sites
stevasaurus 23,534 #5 Posted September 11, 2016 That is pretty nifty Cleat. You have given that some thought. Share this post Link to post Share on other sites
MalMac 1,333 #6 Posted September 11, 2016 I was just wondering and thinking that the newer style going through that casing is just the perfect set up to get moisture in there. Kinda like the throttle and choke cables freezing up when they switched from the K series to the Magnums. Share this post Link to post Share on other sites
doc724 925 #7 Posted September 12, 2016 20 hours ago, MalMac said: Kinda like the throttle and choke cables freezing up when they switched from the K series to the Magnums. I am so relieved to know that others had this problem! I thought it was only me and it was due to the fact that I washed the engines in the fall. Yup, every winter one of the cables was frozen so I either stopped washing the engines in the fall or learned to hang a trouble light facing the cables (and turn it on) the night before a storm to make sure the darn cables would move when I needed to start it in the morning. Share this post Link to post Share on other sites
