russellmc301 600 #1 Posted September 7, 2016 well i got my rebuilt kits for my carb today and i seen my head gasket was bad so i need a new one of those. my dad said the points have white corrosion on them so it would be good to get new points. so i figured it im going to fix the head gasket and points might as well find out what other gaskets i need to rebuild it. i heard there isn't a K-91 "rebuildkit" for sale but i could still get all the gaskets seperate. so what gaskets do i need to rebuild my engine? Share this post Link to post Share on other sites
Wildhorse 303 #2 Posted September 8, 2016 I would just take a piece of 400grit sandpaper and run it between points before buying new, it doesn't take much to clean them just check gap after. As far as gaskets go I wouldn't replace any that aren't bad unless your tearing down motor completely. Head gasket is easy just make sure you clean well and torque head bolts to proper ft/lb and in correct sequence. Just my and what I would do if motor is running good. If it isn't broke don't fix it is what I was always told. 1 Share this post Link to post Share on other sites
russellmc301 600 #3 Posted September 8, 2016 makes sense ill go ahead and check all the gaskets and make sure they are in good working order. Share this post Link to post Share on other sites
