Dball 12 #1 Posted September 5, 2016 Hello guys I have a bit of an issue which I think I am missing parts to hook the plow to my 520h which I purchased recently on the middle of the plow where the part fits in between the channels of the plow frame and bolts to the welded 2nd center bar from the front of the plow back how do I hook my Hydro lift to the plow as their isn't any hole big enough to hook the hydrolic lift to i think something is missing also their is a peice on the rear of the plow in which u put a dual notched steel square with round stock on both ends one peice is welded in the other round stock is removable and slides trough the plow. Is their something on the rear axle that the very end of the plow slides into and locks around the 2in or so dia peice of round stock kinda like the quick attach? I'm sorry if I couldn't explain things better but I don't know the names of some of the parts or the parts I think of missing Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,263 #2 Posted September 5, 2016 These threads may explain what you need Garry 1 Share this post Link to post Share on other sites
Ed Kennell 46,166 #3 Posted September 6, 2016 Looks like Garry has your questions covered Dball. to BTW, where is Fennelton? I thought I knew every town in PeeeAaaaa. Share this post Link to post Share on other sites
Dball 12 #4 Posted September 6, 2016 Okay now I have both them parts but still Un sure who the lift hooks to the mid mount bracket and how the part on the back of the plow is held onto the tractor but both parts on the photos are what I am talking about just don't know where or how they hook to my 520 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,263 #5 Posted September 6, 2016 This manual should do it for you It does not show the extra parts to move the assembly forward on the 520 with the forward swept front axle but the rest is the same. Garry Share this post Link to post Share on other sites
Dball 12 #6 Posted September 6, 2016 Can any one give me dimensions from the little peice of steel extension that bolts to the mid section then goes to the lifting arm on the hydrolic as I can make that then I need the part that clamps around the axle so if any one can give me dimensions on that also would be grate thanks u all very much as this has been very helpful ! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,263 #7 Posted September 6, 2016 Short lift link 102665 replaced by 105052 1/4"x1-1/4"x5-1/4" flat bar 3/8" pins 5/8" long Pins 4-1/8" center to center When I make a link I use 3/8" bolts and cut the threads off. I drill holes in the bar and stick the bolts into them. Then weld the bolt heads to the back side of the bar. Do one bolt and try the fit for alignment. You may find the link needs a bit of offset and installing the second bolt the opposite direction may be sufficient. When the bolts/pins are welded they reduce wear in the holes because they are nice and square to the arms. Garry Share this post Link to post Share on other sites
Ed Kennell 46,166 #9 Posted September 6, 2016 Here is a pic of one style of axle bracket to give you an idea. Not sure you want to manufacture on of these when there are available for $30-$60. If you want to go cheap, you could make a bracket from two pieces of 2X2 angle bolted to the axle with a hole for the plow pin. You would have to remove one rear wheel to install the pin when installing or removing the plow frame. 1 Share this post Link to post Share on other sites
Ed Kennell 46,166 #10 Posted September 6, 2016 Some good pics here if the parts you need. Share this post Link to post Share on other sites
Dball 12 #11 Posted September 6, 2016 Thank you all very much as this has been very helpful I work in a machine shop programing and running cnc machines so if it isn't made anymore or I can justify my time spent on something being sold for x amount I can make it or if I'm just bored and have alot of run time I will make it because I'm bored lol but thank you all once again 1 Share this post Link to post Share on other sites
Ed Kennell 46,166 #12 Posted September 6, 2016 2 minutes ago, Dball said: I can make it or if I'm just bored and have alot of run time I will make it because I'm bored Luv the "do it myself attitude" . With the skills, equipment, and time, go for it. Again, where is Fennelton? Share this post Link to post Share on other sites
Dball 12 #13 Posted September 6, 2016 Butler about 40 to 30 Minutes from Pittsburgh pa Share this post Link to post Share on other sites
Walt 339 #14 Posted September 10, 2016 On 9/6/2016 at 3:03 PM, Dball said: Thank you all very much as this has been very helpful I work in a machine shop programing and running cnc machines so if it isn't made anymore or I can justify my time spent on something being sold for x amount I can make it or if I'm just bored and have alot of run time I will make it because I'm bored lol but thank you all once again I got my mount from WheelHorseMan1000 he is in the vendors section. Share this post Link to post Share on other sites
Dball 12 #15 Posted September 11, 2016 Thanks so Walt for the heads up but I had just finished making mine all that's left is the Lil bar for the hydrolic lift Share this post Link to post Share on other sites
Ed Kennell 46,166 #16 Posted September 11, 2016 44 minutes ago, Dball said: just finished making mine Share this post Link to post Share on other sites
Dball 12 #17 Posted September 12, 2016 I had tried to post pics but it keeps saying file to large ect I wanted to also post pictures of my 520h but I keep getting denied kinda tics me off Share this post Link to post Share on other sites
Ed Kennell 46,166 #18 Posted September 12, 2016 http://www.wheelhorseforum.com/store/ If you go here and become a supporter, the picture file size goes away. Share this post Link to post Share on other sites
