RedHorse54 578 #1 Posted September 5, 2016 does anyone know what store I can go to, to find a pulley that will fit a Clinton B1290? Thanks Share this post Link to post Share on other sites
AMC RULES 37,237 #2 Posted September 5, 2016 Try "adding a new classified" here... http://www.wheelhorseforum.com/classifieds/wanted/ 1 Share this post Link to post Share on other sites
wallfish 18,652 #3 Posted September 5, 2016 http://www.surpluscenter.com/Pulleys/Finished-Bore-Pulleys/?page_no=1&fq=ATR_Grooves:1&fq=ATR_Bore_Fractional:3/4\" McMaser Carr Tractor Supply The size is 3/4" bore by 2.5 OD if it's the drive pulley for RJ or Suburban. Belt is 1/2 wide Share this post Link to post Share on other sites
RedHorse54 578 #4 Posted September 5, 2016 30 minutes ago, wallfish said: http://www.surpluscenter.com/Pulleys/Finished-Bore-Pulleys/?page_no=1&fq=ATR_Grooves:1&fq=ATR_Bore_Fractional:3/4\" McMaser Carr Tractor Supply The size is 3/4" bore by 2.5 OD if it's the drive pulley for RJ or Suburban. Belt is 1/2 wide Thanks wallfish. Do you know what size drive belt the 58 RJs would have? Share this post Link to post Share on other sites
Skeeters65 45 #5 Posted September 5, 2016 Hey Wallfish is it the same pulley on a K91? Share this post Link to post Share on other sites
wallfish 18,652 #6 Posted September 5, 2016 Yes, just measure the size of the shaft to be 100% sure. Shaft sizes are common sizes from engine manufacturer to engine manufacturer except for specific spec applications. For example, I have a K91 with a 5/8 shaft, no key way and threaded on the end for a castle nut. Also have quite a few others with the very common 3/4" shaft. Then there are tapered shaft applications like generators and blowers. RJ-58 drive belt is 1/2" W x 29" L Share this post Link to post Share on other sites
