JoeM 9,549 #1 Posted August 31, 2016 I picked these up the other day with a package deal and I am not sure if they are WH parts or not? If anyone can identify them let me know. thanks, Joe Share this post Link to post Share on other sites
wallfish 19,045 #2 Posted August 31, 2016 Yes, WH factory parts The bracket is for mounting a suburban snow/dozer blade to the RJ The pedal is for that blade also and is used to pull the index pin so the blade can be swiveled side to to side using a small rope connected to the corners 4 Share this post Link to post Share on other sites
JoeM 9,549 #3 Posted August 31, 2016 thanks Mr. Wallfish! that took 5 minutes, I knew I could count on Red Square to set me straight! 1 Share this post Link to post Share on other sites
wallfish 19,045 #4 Posted August 31, 2016 No problem! Where are the pics of the RJ and suburban Blade you scored in the package deal? Share this post Link to post Share on other sites
DennisThornton 4,773 #5 Posted August 31, 2016 Unbelievable! This site should charge more for admission! 2 Share this post Link to post Share on other sites
JoeM 9,549 #6 Posted August 31, 2016 Actually, I got old snow thrower. When I loaded up the thrower there was this pile of parts and he threw them in. There was some blades there but they were modified to fit the rear axle type set up. Cobbled up you know. That could explain these items not ever being used??? Share this post Link to post Share on other sites
