cdr_warsstar 106 #1 Posted August 30, 2016 I have a Raider 10 with the 5-1421 mower deck and it doesn't seem to be hooked up right. If I drop it from the travel height, and with the deck wheels in the highest cut position, it cuts the grass down to about an inch. So I have to mow with the deck in the travel position, which isn't terribly effective. I looked at the deck's manual and everything seems to be right. I have pictures attached and I can get more if needed. another picture Share this post Link to post Share on other sites
Ed Kennell 44,096 #2 Posted August 30, 2016 4 minutes ago, cdr_warsstar said: I have a Raider 10 with the 5-1421 mower deck and it doesn't seem to be hooked up right. If I drop it from the travel height, and with the deck wheels in the highest cut position, it cuts the grass down to about an inch. So I have to mow with the deck in the travel position, which isn't terribly effective. I looked at the deck's manual and everything seems to be right. I have pictures attached and I can get more if needed. Put the pin under this curved channel and your problems will go away. Share this post Link to post Share on other sites
Ed Kennell 44,096 #3 Posted August 30, 2016 (edited) 44 minutes ago, Ed Kennell said: 50 minutes ago, cdr_warsstar said: BTW, you are missing the guide wheel for the deck idler tensioning plate. Also the attach-a- matic should be locked closed with a hairpin clip on the left side. If it gets bumped, the deck could drop damaging the belt or your fingers. Edited August 30, 2016 by Ed Kennell 1 Share this post Link to post Share on other sites
cdr_warsstar 106 #4 Posted September 1, 2016 I'll try that and get that pin in tomorrow. There's a groove worn into the rod where the bushing goes, but I'll see what I can do. Thanks! Share this post Link to post Share on other sites
Don1977 605 #5 Posted September 1, 2016 I don't know how to adjust that type of deck, but it's way to low in the front. Share this post Link to post Share on other sites
cdr_warsstar 106 #6 Posted September 1, 2016 Ed, that was it, thanks man! 1 Share this post Link to post Share on other sites
Ed Kennell 44,096 #7 Posted September 3, 2016 Your deck is not the first one I have seen with the rod installed incorrectly. You should also get a wheel on that tensioning plate and a pin in the the tach-a-matic. BTW, to 1 Share this post Link to post Share on other sites
