Tinys 25 #1 Posted August 29, 2016 (edited) Need some help identifying my deck model number. It's on an 88 520h. Was told it's a 48 but ordering some parts today and found out its a 42. Should've pulled the tape earlier. 05 48sc01 is what I was told but that's wrong. Has 2 belt covers the blade drive belt is 85" and the idler pulley is 3.75 " outside diameter. The belt for the 48 was 89" I think. Too long so we measured the old one at the parts counter and got 85. The new idler pulley for the 48 is 3.25". I'll go out in a few and get some pics of the deck. Thanks Tom Edited August 29, 2016 by Tinys Adding pictures Share this post Link to post Share on other sites
Bert 805 #2 Posted August 29, 2016 Your right, that's a 42 inch deck. I can't help with a number but the renforcment rod welded around the outside bottom edge tells me that its correct time frame for your 88 520. That may help you or ordering parts 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #3 Posted August 30, 2016 Garry 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #4 Posted August 30, 2016 (edited) 42" SIDE DISCH DECKS: the SPINDLE bel is # OEM 6738 at 86" long. The MULE DRIVE belt is OEM #102742 (or 94-2501) at 103" length. On-line for $19 and $22 respectively. OEM belts are far superior to the after-market brands...IMHO. Edited August 30, 2016 by daveoman1966 1 Share this post Link to post Share on other sites
Tinys 25 #5 Posted August 31, 2016 Thank you all for the help. I'll get more time this weekend to work on it again. Hopefully I'llhave the correct parts then.lol On 8/29/2016 at 8:11 PM, gwest_ca said: Garry Other than being the file God how were you able to figure that out? My hats off to you. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #6 Posted August 31, 2016 I went to the attachment list for your tractor/year and found the 05-42MS05 was the deck for 1988. I just knew the deck models following this one would be the same as far as connecting to your tractor. The 1989 model was 15-42SC01 and after that there are no 42" SD decks listed for the 520. Here is the 1988 attachment list The D&A is the Details and Attachment list. This info originally came from here Garry 1 Share this post Link to post Share on other sites
