stevebo-(Moderator) 8,532 #1 Posted December 29, 2008 guys, i just swapped a set of augs today from one to another and after looking at it tonight i noticed i may have out them on backwards... If you were sitting on the tractor looking down at the top of the tires, which way should the VVVVVVV point? thanks- Share this post Link to post Share on other sites
here 4 the horses 1 #2 Posted December 29, 2008 V should be pointing at the front! , jeff Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted December 29, 2008 There's a lot of guys that swear that ags on the front wheels should point backwards. I've never had Ags on the front, so cant comment... Share this post Link to post Share on other sites
here 4 the horses 1 #4 Posted December 29, 2008 i hate ags on the front i always use 3 bar on the front and work great and not to mention look good too! , jeff Share this post Link to post Share on other sites
mcwh1950 2 #5 Posted December 29, 2008 mine is like this. Share this post Link to post Share on other sites
ironcitymadman 0 #6 Posted December 29, 2008 sidewalls usually have a rotation direction arrow on'em Share this post Link to post Share on other sites
stevebo-(Moderator) 8,532 #7 Posted December 29, 2008 guys, do we all agree that they should be like smitty's in the picture? i am talking about the rear tires, i do not have them on the front. thanks- :hide: Share this post Link to post Share on other sites
Jim_M 179 #8 Posted December 29, 2008 Steve, The rears should be put on like the ones in Smitty's picture. Jim Share this post Link to post Share on other sites
jerrell 1 #9 Posted December 29, 2008 Steve the tread is pointed that way for the purpose of clealing the mud out , if you run the ags backward the mud will not fall out of the space created by the tread ridges, when the tire spins mud would slick over the intire tread area and it would be just like not haveing ags on at all, i think the wide area at the bottom of the v causes the mud to compact itself and would adhere to the tire Share this post Link to post Share on other sites
Teddy da Bear 11 #10 Posted December 29, 2008 V should be pointing at the front! Unless your looking at it from underneath the tractor... Then they point toward the back... :D Share this post Link to post Share on other sites
beast owner 1 #11 Posted December 30, 2008 I agree with the way they are on Smitty's tractor. jerrell explained it very well in his post Sometimes we have put them backwards on the combine so we can backout of the mud holes when we have a wet fall :omg: Share this post Link to post Share on other sites
Jim_M 179 #12 Posted December 30, 2008 I agree with the way they are on Smitty's tractor. jerrell explained it very well in his post Sometimes we have put them backwards on the combine so we can backout of the mud holes when we have a wet fall Yup, you just brought back some memories. I used to run duals on my Gleaner in wet years, they were mounted backwards so I had a set aiming both ways. Share this post Link to post Share on other sites
beast owner 1 #13 Posted December 31, 2008 JIM_M I remember one year we had to wait for the ground to freeze, we would start around midnight and work until about 8:00 am. when the sun would make it greasy on top. Share this post Link to post Share on other sites
