Skeeters65 45 #1 Posted August 25, 2016 Just curious what the length is? Mine doesn't seem right, seems too long. It is about 32.5" from ball to ball on the cable. 35" pin hole to pin hole. Thanks. Share this post Link to post Share on other sites
oliver2-44 11,234 #2 Posted August 25, 2016 The 1960 and 61 suburban's have different length cables. (I suspect because they have different transmissions) Go to our vendor section and Wheelhorseman1000 sells reproduction cables. Look up your year to find the correct cable length. Share this post Link to post Share on other sites
russellmc301 601 #3 Posted August 25, 2016 i got the measurements as you did on my sububurban 400 lift cable. try reconfigureing the cable around. Share this post Link to post Share on other sites
Skeeters65 45 #4 Posted August 26, 2016 1 hour ago, russellmc301 said: i got the measurements as you did on my sububurban 400 lift cable. try reconfigureing the cable around. Hmmm In the tool box there is the tab that holds the cable in place. Is there something that holds the cable in place in the front? Thanks 1 Share this post Link to post Share on other sites
russellmc301 601 #5 Posted August 26, 2016 well mine is under restoration now so i couldn't tell you. Share this post Link to post Share on other sites
