fatpigtkd 0 #1 Posted August 25, 2016 where can i find parts for peerless 601-001 transmission or whole thing the mower is a b112 Share this post Link to post Share on other sites
Old red 16 #2 Posted August 25, 2016 These parts should still be available online. peerless is put out by tecumseh. Look on partstree.com for a schematic and search for the parts. Usually only thing that wears in them is the shift keys and the chain breaks a link. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,478 #3 Posted August 25, 2016 Here is the ipl Garry Share this post Link to post Share on other sites
daveoman1966 3,884 #4 Posted August 25, 2016 Just an FYI.... here are the other mowers with that same trans: 02-08BP01 1980 B-82 4-Speed Briggs 191707-1136-01 8 Peerless 601-001 02-11BX01 1980 B-112 4-Speed Briggs 252707-0206-01 11 Peerless 601-001 02-08BP02 1981 B-82 4-Speed Briggs 191707-1136-01 8 Peerless 601-001 02-08BP03 1981 B-82 4-Speed Briggs 191707-1160-01 8 Peerless 601-001 02-11BX02 1981 B-112 4-Speed Briggs 252707-0206-01 11 Peerless 601-001 02-11BX03 1981 B-112 4-Speed Briggs 252707-0222-01 11 Peerless 601-001 02-08BX01 1982 B-85 5-Speed Briggs 191707-1136-01 8 Peerless 601-001 02-11BH01 1982 SB-371 4-Speed Briggs 252417-0245-01 11 Peerless 601-001 A2-083201 1982 LT-832 4-Speed Briggs 191707-1160-02 8 Peerless 601-001 A2-083202 1983 LT-832 4-Speed Briggs 191707-2138-01 8 Peerless 601-001 D2-113601 1983 LT-1136 4-Speed Briggs 252707-0657-01 11 Peerless 601-001 D2-113701 1983 LT-1136 4-Speed Briggs 252707-0657-01 11 Peerless 601-001 D2-163701 1983 LT-1637 Twin 4-Speed Briggs 402707-0132-04 16 Peerless 601-001 Share this post Link to post Share on other sites
fatpigtkd 0 #5 Posted August 30, 2016 On 8/24/2016 at 8:38 PM, Old red said: These parts should still be available online. peerless is put out by tecumseh. Look on partstree.com for a schematic and search for the parts. Usually only thing that wears in them is the shift keys and the chain breaks a link. the two gears i need are no longer around im hoping i can find a used transmission On 8/25/2016 at 5:57 PM, daveoman1966 said: Just an FYI.... here are the other mowers with that same trans: 02-08BP01 1980 B-82 4-Speed Briggs 191707-1136-01 8 Peerless 601-001 02-11BX01 1980 B-112 4-Speed Briggs 252707-0206-01 11 Peerless 601-001 02-08BP02 1981 B-82 4-Speed Briggs 191707-1136-01 8 Peerless 601-001 02-08BP03 1981 B-82 4-Speed Briggs 191707-1160-01 8 Peerless 601-001 02-11BX02 1981 B-112 4-Speed Briggs 252707-0206-01 11 Peerless 601-001 02-11BX03 1981 B-112 4-Speed Briggs 252707-0222-01 11 Peerless 601-001 02-08BX01 1982 B-85 5-Speed Briggs 191707-1136-01 8 Peerless 601-001 02-11BH01 1982 SB-371 4-Speed Briggs 252417-0245-01 11 Peerless 601-001 A2-083201 1982 LT-832 4-Speed Briggs 191707-1160-02 8 Peerless 601-001 A2-083202 1983 LT-832 4-Speed Briggs 191707-2138-01 8 Peerless 601-001 D2-113601 1983 LT-1136 4-Speed Briggs 252707-0657-01 11 Peerless 601-001 D2-113701 1983 LT-1136 4-Speed Briggs 252707-0657-01 11 Peerless 601-001 D2-163701 1983 LT-1637 Twin 4-Speed Briggs 402707-0132-04 16 Peerless 601-001 thanks for the info Share this post Link to post Share on other sites
