Mike's 520HC 5 #1 Posted August 23, 2016 I sold the 520HC earlier this year and acquired the 1995 266H. Ran great up to last night. Mowed, shut it off to clean the deck and it will start but won't stay running. It will continue running if the starter is engaged, once starter disengages, it won't run. Full tank, removed fuel cap to vent, I replaced the plugs, checked the fuel pump to ensure flow, checked all of the fuses, seat switched jumped, removed the float bowl and cleaned, check the operation of the fuel solenoid and cleaned it. all fine. Any suggestions? Thank you. Share this post Link to post Share on other sites
shallowwatersailor 3,220 #2 Posted August 23, 2016 Download the engine manual. Also check the Demystification Manual for the wiring in the different modes. Are you sure that it is getting spark when turning over with the starter? Share this post Link to post Share on other sites
WHX?? 54,478 #3 Posted August 23, 2016 Possible bad igniton switch?? Share this post Link to post Share on other sites
Mike's 520HC 5 #4 Posted August 23, 2016 Funny, I was just looking at it again and thought maybe the ign. switch is bad. I'll check it, but makes sense...getting spark in cranking position. Thanks!! Share this post Link to post Share on other sites
cleat 8,715 #5 Posted August 23, 2016 (edited) Make sure the PTO switch is firmly off. If you were just mowing with it maybe it is not fully off ? Also try removing the seat jumper. my little 210 shuts down with the seat switch jumped but stays running with it simply unplugged. Just a thought. Edited August 23, 2016 by cleat 1 Share this post Link to post Share on other sites
SylvanLakeWH 30,451 #6 Posted August 23, 2016 22 minutes ago, cleat said: Make sure the PTO switch is firmly off. If you were just mowing with it maybe it is not fully off ? That PTO switch issue happened to me as well...pushed it a tad and VVVRRROOOMMM...worth checking out! 1 Share this post Link to post Share on other sites
Tuneup 1,452 #7 Posted August 25, 2016 My red-neck wired machine was very intermittent. After a few minutes of running, odd things would happen that cleared only when I jumped the battery to the (+) coil. I'd track the fault to wires hot to the touch everywhere - ignition switch, regulator, PTO and ammeter. A full rewire was warranted. The ignition switch was cleaned but later replaced, the ammeter was resistive, the regulator later puked and was a source of wire overheating when pumping out 17 VDC, and the PTO needed a good dis-assembly and cleaning. Welcome to the club! Share this post Link to post Share on other sites
