slammer302 2,157 #1 Posted August 23, 2016 I just bought a 417-8 with a electric lift option. I was thinking about switching it over to my 310-8 that i have been using to mow with most of the summer. I was wanting to here from other members that have a electric lift and get sum input on how they like it or why they don't like about it. 1 Share this post Link to post Share on other sites
seven 202 #2 Posted August 23, 2016 Never heard of electric lift is it factory.can you get a picture of it 1 Share this post Link to post Share on other sites
slammer302 2,157 #3 Posted August 23, 2016 It is a factory option. Can't post picks till i renew my supporter status but maybe someone else can hook us up with a pic. 1 Share this post Link to post Share on other sites
wheelhorseman 3,256 #4 Posted August 23, 2016 Here is some pictures of one 4 Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted August 23, 2016 The lift pictured above is an earlier model, the setup for the 3,4 and 500 series tractors is pictured at the end of this thread in the gallery: I had one on a 518, I liked it lifting a snowblower, but didnt like it with a plow or grader blade. I dont like hydraulic lifts for those implements either - I prefer the manual lift so I can feel how deep the blade is cutting and can vary the down pressure by pushing or pulling on the lift arm. 2 Share this post Link to post Share on other sites
elliot ness 1,916 #6 Posted August 23, 2016 Yup they made a few through out the years , I have had two. 1 Share this post Link to post Share on other sites
Jerry77 1,218 #7 Posted August 23, 2016 7 hours ago, sorekiwi said: The lift pictured above is an earlier model, the setup for the 3,4 and 500 series tractors is pictured at the end of this thread in the gallery: I have one on my 516h - it is really strong - that is what I like about it because I'm not anymore...if I was, I would prefer the manual lift. I had one on a 518, I liked it lifting a snowblower, but didnt like it with a plow or grader blade. I dont like hydraulic lifts for those implements either - I prefer the manual lift so I can feel how deep the blade is cutting and can vary the down pressure by pushing or pulling on the lift arm. 3 Share this post Link to post Share on other sites
pfrederi 20,305 #8 Posted August 23, 2016 Electric Lifts are much slower than hydros Share this post Link to post Share on other sites
slammer302 2,157 #9 Posted August 23, 2016 Will a electric lift give down pressure if used with a solid lift link? Share this post Link to post Share on other sites
oldredrider 2,553 #10 Posted August 23, 2016 Yes. Pressure either direction. 1 Share this post Link to post Share on other sites
slammer302 2,157 #11 Posted August 23, 2016 Thanks for the info guys. I'm still not sure what I'm going to do but you gave me sum things to think about. Share this post Link to post Share on other sites
sorekiwi 761 #12 Posted August 24, 2016 10 hours ago, slammer302 said: Will a electric lift give down pressure if used with a solid lift link? Yes it will, Ironically its one of the things I dont like about it - because of the lack of "feel" its very easy to apply too much down-pressure and take too much weight off the front wheels. 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,836 #13 Posted September 19, 2016 It would be cool to add one to my 416-8. I looked underneath Slammer's 417-8 with the electric lift when we were both at the Mid-Mo M&G Saturday. It wouldn't be too hard to do. I wonder what the specs are on the actuator used, i.e. retracted length, extended length, force, etc.? Share this post Link to post Share on other sites
DennisThornton 4,773 #14 Posted September 19, 2016 On 8/23/2016 at 10:57 PM, sorekiwi said: Yes it will, Ironically its one of the things I dont like about it - because of the lack of "feel" its very easy to apply too much down-pressure and take too much weight off the front wheels. I think this is an often overlooked if not completely missed aspect! The manual lift offers SO much feedback AND control that in many cases it is COMPLETELY superior to a much more powerful but completely insensitive hydraulic or electric control! I was SO surprised to discover this and now I would NOT want to give that up! For some uses at least! I can move dirt on grassy areas and NOT remove the grass. Push snow off of thawed gravel driveways and not remove the gravel. Power is great but control is sometimes even better! 3 Share this post Link to post Share on other sites
doc724 925 #15 Posted September 19, 2016 I wholeheartedly agree with Dennis about the feedback from a manual lift. However, as I age, lifting a blower or a tiller, even with a helper spring, is not as much fun as it used to be. 3 Share this post Link to post Share on other sites
DennisThornton 4,773 #16 Posted September 20, 2016 1 hour ago, doc724 said: I wholeheartedly agree with Dennis about the feedback from a manual lift. However, as I age, lifting a blower or a tiller, even with a helper spring, is not as much fun as it used to be. And I should have noted that I have my blade set for maximum power of lift, not for maximum lift. In other words, minimum force to lift but not as high instead of maximum height by maximum force! And I should further note, blade! Not blower or tiller! But I think the blade is where the maximum feel is the most important. And, while it is still easy enough for me, the fun is still not in the lifting, but in the results... And I suppose in later years I might not care so much about pushing gravel or grass blades and perhaps actually prefer a hydro or electric lift... Share this post Link to post Share on other sites
sorekiwi 761 #17 Posted September 20, 2016 8 hours ago, T-Mo said: It would be cool to add one to my 416-8. I looked underneath Slammer's 417-8 with the electric lift when we were both at the Mid-Mo M&G Saturday. It wouldn't be too hard to do. I wonder what the specs are on the actuator used, i.e. retracted length, extended length, force, etc.? A little bit of info in this thread Terry: 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,836 #18 Posted September 20, 2016 9 hours ago, sorekiwi said: A little bit of info in this thread Terry: Thanks, that is what I'm looking for. Share this post Link to post Share on other sites
Jerry77 1,218 #19 Posted October 6, 2016 On 9/19/2016 at 9:37 PM, DennisThornton said: And I suppose in later years I might not care so much about pushing gravel or grass blades and perhaps actually prefer a hydro or electric lift... Yeah Dennis - I got old ( how did that happen??) and electric or hydro is a must - gave my 314-8 to my son and bought 516H with an electric lift -Hope you don't need one for many years... Share this post Link to post Share on other sites
