Pollack Pete 2,273 #1 Posted August 21, 2016 This has probably been discussed here many times before,but I don't know how to do a search for discussed info.Anyone know of a source and or part numbers for a set of ignition points and condenser for a WH D-250? Had mine running today and it quit suddenly.Thought it ran out of gas.Put in gas.Still no run.Checked for spark.....nothing.Tried a new coil.Still no spark.Gotta be points and condenser.Thanks for any and all info. Share this post Link to post Share on other sites
squonk 48,166 #2 Posted August 21, 2016 Renault parts! If you can take the points and cond out, and have Napa near by that has kept the books around, they can match them up in an Echlin buyers guide. If they don't, take some pics and post them and I'll see what I can find. I kept a lot of the books when they went all electronic cataloging. Much easier to use a book when trying to match a pic. I used to have to do this for Continental engines. If you can do it for those, you can do it for anything! Share this post Link to post Share on other sites
DougC 2,644 #3 Posted August 21, 2016 You might file the ign points and see if that does it. My '56 Ford sits without being used for more than 6 months at a time and will die unexpectedly after starting and running sometimes. Last 2 times Had spark again after I used a point file. Share this post Link to post Share on other sites
squonk 48,166 #4 Posted August 21, 2016 See if either one of these look like your points: http://s7d9.scene7.com/s7/zoom/flasht_zoom.jsp?company=GenuinePartsCompany&sku=482794&config=GenuinePartsCompany/GPC-DBLCLK-ZOOM&locale=en&vc=image=GenuinePartsCompany/482794,GenuinePartsCompany/482796,GenuinePartsCompany/482795 http://s7d9.scene7.com/s7/zoom/flasht_zoom.jsp?company=GenuinePartsCompany&sku=97924&config=GenuinePartsCompany/GPC-DBLCLK-ZOOM&locale=en&vc=image=GenuinePartsCompany/97924,GenuinePartsCompany/482831 Share this post Link to post Share on other sites
Pollack Pete 2,273 #5 Posted August 21, 2016 Thanks Sqonk.Neither contact set looks like mine.My primary wire from the coil goes to an insulated stud that goes through a hole in the side of the distributor.The movable contact spring attaches to this stud inside the distributor.Problem with all the local Napa stores is there's no one working that's over 25 years old.No one can look up parts in a book.Every ones a computer operator. Share this post Link to post Share on other sites
squonk 48,166 #6 Posted August 22, 2016 Get me a pic of the points or a distributior # if you can. Share this post Link to post Share on other sites
stratostar250 934 #7 Posted August 22, 2016 (edited) Had to do a LOT of searching through the forum, but I was doing it for my own keep as well in case I need the numbers one day as well. I found Duane (baerpath) posted this a few years back, Duane had upwards of 6 or 8 d250s in the past, so if there is one person who knows, im sure it'd be him. Send him a PM if you can't find anything. On 5/24/2009 at 5:46 PM, baerpath said: D250 ignition parts (correct ones from Beru original equipment for the Gutbrods) Cap VK 121 condensor ZK 138 rotor EVL 4/6-x polnts KS 381 V If you can't get them by you let me know. Duane Edited August 22, 2016 by stratostar250 Share this post Link to post Share on other sites
Pollack Pete 2,273 #8 Posted August 22, 2016 Squonk,here's a pic of the contact set I need.Couldn't find a distributor number ,at least with out removing distributor. Share this post Link to post Share on other sites
baerpath 517 #9 Posted August 23, 2016 Wheel Horse part number 250826 for the points for a D250 Pete I'll be in Schaghticoke tomarrow give me a call Share this post Link to post Share on other sites
squonk 48,166 #10 Posted August 24, 2016 looks similar to that first one I listed. I'll look in my book but I don't have much faith. Share this post Link to post Share on other sites
squonk 48,166 #11 Posted August 24, 2016 This is the closest I could come up with: # CS251 They are a Renault points set but not quite the same. Sorry http://s7d9.scene7.com/s7/zoom/flasht_zoom.jsp?company=GenuinePartsCompany&sku=97923&config=GenuinePartsCompany/GPC-DBLCLK-ZOOM&locale=en&vc=image=GenuinePartsCompany/97923,GenuinePartsCompany/482830 Share this post Link to post Share on other sites
