redblood 3 #1 Posted August 21, 2016 Hello everyone, my old wheel horse seems to slip going up hills, is there any belt adjustment? Or should belt be replaced from stretching? I think the belts original. Thanks 1 Share this post Link to post Share on other sites
scotty 252 #2 Posted August 21, 2016 No belt adjustments that i know of. I would check the clutch spring to make sure it is pulling back all the way and putting tension on your belt. 1 Share this post Link to post Share on other sites
redblood 3 #3 Posted August 21, 2016 Thanks, thought about that spring, maybe change that first and see if it helps. 1 Share this post Link to post Share on other sites
Ed Kennell 45,732 #4 Posted August 21, 2016 Check the hub keys and the tranny drive pulley key. One of these three may have sheared. It will still drive OK under low load, but slip under higher load. 1 Share this post Link to post Share on other sites
