redblood
72 commando 800
redblood
Hello everyone, my old wheel horse seems to slip going up hills, is there any belt adjustment? Or should belt be replaced from stretching? I think the belts original. Thanks
scotty
No belt adjustments that i know of. I would check the clutch spring to make sure it is pulling back all the way and putting tension on your belt.
redblood
Thanks, thought about that spring, maybe change that first and see if it helps.
Ed Kennell
Check the hub keys and the tranny drive pulley key.   One of these three may have sheared.  It will still drive OK under low load, but slip under higher load.
