snowhound 106 #1 Posted August 20, 2016 Recently picked up a GT 2500 that doesn't move, I've checked the shifter and and it is in the slides correctly. With it in 1st. once and a while something will catch and it will lunge a little but doesn't move which makes me think it is a sheared pin. Anyone have any idea whar could be sheared and how big of a job it is to fix? I do have a 1142 that could be a transmission donor. Ed Share this post Link to post Share on other sites
N3PUY 1,031 #2 Posted August 20, 2016 See if the axle is spinning in a hub. 2 Share this post Link to post Share on other sites
Racinbob 12,510 #3 Posted August 20, 2016 Yea, check both hubs. It only takes one sheared key to stop the tractor. If they are OK then check the input pulley key. You can get new keys at any hardware store and they are easy to replace. 2 Share this post Link to post Share on other sites
snowhound 106 #4 Posted August 21, 2016 Thanks for the replies, the axles aren't spinning in the hubs and the input key is good. This is what I have found out, if i leave it in gear for a little while, maybe 20 to 30 seconds something catches and the tractor will move for a sort distance then there is a soft snapping sound in the transmission and the tractor stops. Due to that I feel there is something sheared in the transmission. I've been offered an 8 speed from a Raider 9 but I don't know if it's compatible with the GT 2500 if not I'll pull the one from the 1142. If anyone has any suggestions please let me know. Ed Share this post Link to post Share on other sites
oldredrider 2,553 #5 Posted August 21, 2016 The transmission from the 1142 is exactly the same model (5086) and is a direct swap. Easy 1 hour job. 2 Share this post Link to post Share on other sites
snowhound 106 #6 Posted August 22, 2016 Thanks for the reply Paul, that is good news I really didn't want to start using the 1142 as a donor I hope to get it going over the coming winter. Ed Share this post Link to post Share on other sites
Tuneup 1,452 #7 Posted August 24, 2016 You have a replacement handy and now can fiddle with gears while the snow flies. It's all good. Share this post Link to post Share on other sites
