oliver2-44 11,071 #1 Posted August 20, 2016 Many of us enjoy using our horses as workers, but there are some things to be said for newer models (gasp) such as a much tighter turning radius. Power steering improves turning with a heavy load, but doesn't improve turning radius. So what could the Ponds have done (which leaves it to us today) to improvethe turning radius on these wonderful machines. (and hopefully keep them close to original looking) Has anybody ground the axle stops back & welded 2 fan gears together? Changed the pivot length of the part the tie rods connect to? Changed to a steering gear setup from another tractor? Added some kind of multiplier? Share this post Link to post Share on other sites
Don1977 605 #2 Posted August 20, 2016 What do you need with a tight turn in Texas with all the room down there. 3 Share this post Link to post Share on other sites
oliver2-44 11,071 #3 Posted August 20, 2016 Lots of turning mowing around the rocks and cactus. Also have to turn sharp and run to avoid the rattle snakes 5 Share this post Link to post Share on other sites
wallfish 18,789 #4 Posted August 20, 2016 My first thought would be to grind down the stops and add some length to the steering triangle thingy where the tie rods connect to get more travel. Just be careful it doesn't go too far and lock in position when turned all the way to either side. What tractor are you working with? If it's a '62, the steering radius on those suck! 1 Share this post Link to post Share on other sites
oliver2-44 11,071 #5 Posted August 20, 2016 I'm mainly thinking about my 312-8 and C series Share this post Link to post Share on other sites
DougC 2,643 #6 Posted August 20, 2016 If I'm not mistaken the 520H has a tighter turn radius than the 300 and 400 series. Mine both turn quite sharp. 1 Share this post Link to post Share on other sites
dodge78 94 #7 Posted August 21, 2016 Look at a scissor lift. They have a good turn radius 1 Share this post Link to post Share on other sites
Pullstart 68,532 #8 Posted August 29, 2016 Turn brakes on the rear end! 1 Share this post Link to post Share on other sites
Heatingman 977 #9 Posted May 21, 2023 Been thinking about doing something on the B-80. Noticed though that part of the problem is clearance to the mowing deck. Would need thinner or smaller front tires, or to space them out farther as well. improving the amount of turn angle would be simple enough. Would just need to modify the actual tie rod mount on the spindles. 1 Share this post Link to post Share on other sites
peter lena 9,559 #10 Posted May 21, 2023 @Heatingman like your detailing , since changing over to HEIM JOINTS at just about every related area , years ago , have no problems or failures . doing a related durability trial on clutch linkage ends , lever points , has resulted in zero failures , and solid / smooth reliability . isn't that what you want ? even have a heim on that pto lever end , in place of the trunnion joint , pete Share this post Link to post Share on other sites
Heatingman 977 #11 Posted May 21, 2023 28 minutes ago, peter lena said: @Heatingman like your detailing , since changing over to HEIM JOINTS at just about every related area , years ago , have no problems or failures . doing a related durability trial on clutch linkage ends , lever points , has resulted in zero failures , and solid / smooth reliability . isn't that what you want ? even have a heim on that pto lever end , in place of the trunnion joint , pete Thanks. I though about, and even purchased a heim joint for the PTO lever. It definitely would reduce the slop a bit. Just have not got around to it. Have many irons in the fire, and its mowing season. Spent most of last summer restoring this machine. Been enjoying just using it this year. Share this post Link to post Share on other sites
peter lena 9,559 #12 Posted May 21, 2023 @Heatingman REMOVE TRUNDLE , 3/8x 24 die nut go over original threads , use cutting oil , note last photo m battery ground bolt start point to engine cable / frame area , enhances , ELECTRICAL RECTIFIER GROUNDING , also note battery tender plug in on choke cable . got plastic washers for sloppy lever start area at h/w store pull out drawer section , silicone grease , solid , smooth . made my improvements to my 3 horses , pete Share this post Link to post Share on other sites
