FlyingRed 7 #1 Posted August 20, 2016 So yesterday I started mowing with my c105 I mowed for about 30 min with no problem. Then it started acting like it was going to stall so i gave it some choke and it came back around...I did this several times until finally it shut off. So I proceeded to take the air filter off and cage and put my hand over the carb and it started right up and stayed running. Question is why did it loose prime on the fuel? And how may I be able to keep it from happeneing again Share this post Link to post Share on other sites
squonk 45,366 #2 Posted August 20, 2016 First guess would be fuel pump failure. Share this post Link to post Share on other sites
SylvanLakeWH 30,448 #3 Posted August 20, 2016 (edited) Assume good / clean gas? I would clean carb while running with spray cleaner at intake and add seafoam to the gas to start. I have a 1982 C 105 and when I first got it the carb was gummed up. Doing the above did the trick and it runs great... And welcome to the Black Hoods Club - Love Em... Good Luck! Edited August 21, 2016 by SylvanLakeWH C 105's have a sea food allergy that may result in severe reactions and possible changes in color other than red. Some have even been known to turn green and of course, cease to become functioning members of the WH family. Share this post Link to post Share on other sites
FlyingRed 7 #4 Posted August 20, 2016 Thanks guys!!! I will try all of the above Share this post Link to post Share on other sites
tunahead72 2,600 #5 Posted August 20, 2016 I've never used either product in my gas, but personally I would try Seafoam over seafood. 😊 3 Share this post Link to post Share on other sites
DougC 2,643 #6 Posted August 20, 2016 1 hour ago, tunahead72 said: I've never used either product in my gas, but personally I would try Seafoam over seafood. 😊 Careful with those small shrimp, they tend to get stuck between the carb needle and seat. Adding a fuel filter is always a good idea if it doesn't have one already and check fuel tank screen for being partially plugged with dirt and crud. Fuel pump failing has already been mentioned. Installing all new fuel line rubber hose is a good thing to do as well. 1 Share this post Link to post Share on other sites
SylvanLakeWH 30,448 #7 Posted August 21, 2016 16 hours ago, tunahead72 said: I've never used either product in my gas, but personally I would try Seafoam over seafood. 😊 14 hours ago, DougC said: Careful with those small shrimp, they tend to get stuck between the carb needle and seat. Adding a fuel filter is always a good idea if it doesn't have one already and check fuel tank screen for being partially plugged with dirt and crud. Fuel pump failing has already been mentioned. Installing all new fuel line rubber hose is a good thing to do as well. Gotta love auto fill... I do really love shrimp though... 1 Share this post Link to post Share on other sites
