toma 12 #1 Posted August 17, 2016 Hi All... I have a New Holland GT22A (Toro/Wheel Horse) 522XI lawn tractor with an electrical problem. The check battery light started coming on (and staying on) most of the time. It does go out for short periods of time. I checked the battery with a voltage meter and it is charging. I checked all the wires around the engine and found that when I press on the wires entering a small plastic box(or module) mounted on the fire wall(next to the relays) the battery check light goes out. It must be a broken wire or bad connection at the box. Can anyone tell me what this box(or electrical module) is used for? I don't want to go cutting wires if this is a important or hard to locate part. The module has 4 wires entering from the bottom 1 orange, 2 red(connected together, and one black. The top reads: 1902 EV2 Thanks, Tom Share this post Link to post Share on other sites
shallowwatersailor 3,220 #2 Posted August 17, 2016 It is the electrical module that senses voltage. Toro used it on the Kohler 5xi tractors and the 264/400XT tractors . Like you found out , the battery is still being charged. It is epoxy sealed and evidently a component/connection breaks down. 1 Share this post Link to post Share on other sites
doc724 925 #3 Posted August 17, 2016 John and I have both had the same problem with that sensor. I have tried to find the sensor OEM but no luck. Toro wants $80 for the sensor so I just put up with the light being on all the time (or I could take out the bulb) 1 Share this post Link to post Share on other sites
WNYPCRepair 1,924 #4 Posted August 17, 2016 Same here, I just ignore it My 522xi works correctly, the GT-22A stays on. Share this post Link to post Share on other sites
toma 12 #5 Posted August 17, 2016 Since this sensor is epoxy sealed do you think its the sensor itself or the wires/connections leading to it? When I put pressure on the wires with my finger the light goes out. Im thinking about trying to release the wire connections from the bottom(unsealed half) of the sensor and redo them? Has anyone tried this? Tom Share this post Link to post Share on other sites
doc724 925 #6 Posted August 17, 2016 I have not tried this myself, but I think that when you put pressure on the wires, you are creating an open circuit. The sensor is nothing more than a simple comparator with alt. voltage on one side and a voltage divider on the other. There is likely an internal short and squeezing the wire eliminates the short. Share this post Link to post Share on other sites
Luvtomow 0 #7 Posted June 9, 2017 I have a similar problem with my 522. Battery light comes and goes. When PTO is engaged I can mow for 10 min or so then engine bogs down,wants to die. If I shut off PTO, back to running strong. Does anyone know resistance specs for electric clutch and procedure for checking? Share this post Link to post Share on other sites
Berco 13 #8 Posted September 26, 2017 i had a similar problem. it happened shortly before my battery died. I noticed that the old one did not have the correct CCA, but about half the requirement. Share this post Link to post Share on other sites
