stevasaurus 23,659 #1 Posted December 27, 2008 I was plowing snow and I tried to move a little more then it could handle...snow was frozen...I had the back wheels turning and wasn't moving...when I tried to back up she wouldn't move. I had to push it back into the garage. I thought maybe I streched the drive belt, so I bought a new one...still no go. With out it running, I put it in gear and the wheels seem locked. With it running it will grind when trying to put it in gear. I also noticed the breakdrum not turning when idleing...not sure about that. I didn't hear anything break and the shifter seems to be OK...with engine off it can be put into gear. Are there numbers on the trans to determine what it is? Is it something that can be fixed? We have been getting our share of snow here, and I was having a ton of fun moving it...need some help...thanks :D Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted December 27, 2008 Check the woodruff keys in both axles. (pull the hubs) If they are OK, check the key on the input shaft, then the key on the engine pulley. Share this post Link to post Share on other sites
Buzz 502 #3 Posted December 28, 2008 With it running it will grind when trying to put it in gear. with engine off it can be put into gear. When it does this is the belt guard on or off? You need the guard on to keep if from grinding while running. Like Terry said, check the keys. Share this post Link to post Share on other sites
WheelHorse_of_course 100 #4 Posted December 28, 2008 WIth the clutch fully engaged is the pulley on the trans turning? Share this post Link to post Share on other sites
BPjunk 184 #5 Posted December 29, 2008 Keep in mind that the brake drum will only move when the axles move, it does not turn with the tractor in neutral. The brake shaft gear is also the pinion gear driving the bull gear. Check the oil in the transmission also, make sure you do not see any metal. Wild Bill in Richmond, Va. Share this post Link to post Share on other sites
stevasaurus 23,659 #6 Posted December 31, 2008 thanks for the tips guys...I wasn't sure how it all worked so as to trouble-shoot without pulling it all apart Been under the weather this last week...looking to check it out this weekend...will let you know what I find. thanks :D Share this post Link to post Share on other sites
stevasaurus 23,659 #7 Posted January 5, 2009 terry, buzz, rolf & wild bill...pulled off the blade, the seat , rear tires...then pulled the hubs...sheared both pins, they have them in stock...pick them up tuesday 1/6. I will wait to hear from you, but I figure on fileing the axil burrs...not bad. Greasing the spindle, cleaning the hubs. I do not have any filings in the trans oil. If the rearend is like a car without positraction...then it seems OK..ie...spin the axil from any side..the other goes in reverse...hold one side and the other doesn't move. I could be very lucky, and I would think there would be some kind of a shear pin somewhere. I sheared one drift pin in half and the other was kind of smashed...I can't believe the power these horses have. Thankyou for your expertise...let me know if I should check something else before I put it back together...try to take pictures of the drift pins...hard to believe they sheared like that........REDSQUARE RULES :banana: :banana: :banana: :D Share this post Link to post Share on other sites
WheelHorse_of_course 100 #8 Posted January 5, 2009 Steve, sounds like you got it. Well done... :hide: Share this post Link to post Share on other sites
stevasaurus 23,659 #9 Posted January 7, 2009 well...I tried...the woodfuff keys were the problem, and the tractor is up and running ...got to use it today as we got 2 inches of snow. The problem is that I took some pictures, uploaded them into photobucket in a folder...but I can't seem to get them into here. Before, I could click on a picture, right click, do a copy and paste them into this message. I was using the IMG code, but copy is not an option. Any ideas. :D Share this post Link to post Share on other sites
WheelHorse_of_course 100 #10 Posted January 7, 2009 Steve Once you click the IMG button put your cursor between the two brackets ][ and then use paste to insert the code for the picture. Best of luck. :hide: Share this post Link to post Share on other sites
kpinnc 17,618 #11 Posted January 7, 2009 Well, I can tell you that Photobucket has done some strange stuff lately. If you hover over the pic, roll down to the IMG option, LEFT click to highlight it, then right click. Instead of rolling to "Copy" after the right click, just hit the "c" key on your keyboard. For whatever reason, I can click on "copy" after highlighting it, but the IMG code does not copy for me now, as it always has. Do I have an answer? Same thing happens on any one of 3 computers I use. Go figure... Kevin Share this post Link to post Share on other sites
stevasaurus 23,659 #12 Posted January 7, 2009 computors...it is a love___hate relationship...give me something red and a 9/16,3/8,5/ 8...maybe I figured out the photobucket...I need a defrag Share this post Link to post Share on other sites
stevasaurus 23,659 #13 Posted January 7, 2009 somehow the process has changed...here is what I ended up doing.. once you have your pics in photobucket... 1.put mouse on picture 2.select IMG code...left click 3.move mouse to purple window and right click 4.select copy 5.go to forum and right click and select paste BOOM SHAKALAKA Try that... :banana: :banana: Share this post Link to post Share on other sites
