Kungfil 49 #1 Posted August 12, 2016 Done alot of searching on the forum and not finding much on this....i apologize in advance if not searching correctly or not posting this in the appropriate place in redsquare. So, when i engage the d200 to run an attachement, i see very small shards of metal floating around in the air at the back side/motor side of the clutch assembly. I dont really hear any grinding or anything, but obviously something is. Ive read the manual abit about clutch maintanence and mentions of moly grease and inspections etc. But if you never done it before, not so easy to know what to look for. Could it be it just needs a good greasing. What would be unbelievably cool is if there were a video showing the whole process. Thoughts anyone?, thanks in advance. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,008 #2 Posted August 12, 2016 Don't know the answer. Just giving this a bump to the top. Garry Share this post Link to post Share on other sites
tommyg 157 #3 Posted August 20, 2016 How do you know they're "shards of metal" in the air. Might they be a bit of the clutch surface that is worn off every time you engage? Share this post Link to post Share on other sites
