ikbendennis 3 #26 Posted August 12, 2016 and thats for the hi and low ?? Share this post Link to post Share on other sites
stevasaurus 23,812 #27 Posted August 12, 2016 (edited) No, that is to show you what an 1" looks like. You do not and can not have a hi/low in that transmission. I am still trying to verify the diameter of your axles. Did you find a model number? Did you look at the link?? Edited August 12, 2016 by stevasaurus Share this post Link to post Share on other sites
ikbendennis 3 #28 Posted August 12, 2016 okey but my axel less than 1 inch is that possible ? Share this post Link to post Share on other sites
stevasaurus 23,812 #29 Posted August 12, 2016 No it is not possible. It is either 1" or it is 1 1/8"...that is all it can be. It looks like it is 1" and that would be right for that transmission. Share this post Link to post Share on other sites
ikbendennis 3 #30 Posted August 12, 2016 but is strange it is 23 mm so less than 1 inch Share this post Link to post Share on other sites
stevasaurus 23,812 #31 Posted August 12, 2016 (edited) Maybe your old hub wore down the axle. Try measuring the other side. Did you find a model number for your horse?? Also try measuring around the axle...the circumference...should be 79.7mm. Try different places on the axle. Edited August 12, 2016 by stevasaurus Share this post Link to post Share on other sites
ikbendennis 3 #32 Posted August 12, 2016 the other side i cant get it off its stuck i find some model numbers its a 1971 wheelhorse raider 12 whit a 4 speed trans and a 12 hp kohler engine and do u know that the original seat is for a wheelhorse ?? 1 Share this post Link to post Share on other sites
stevasaurus 23,812 #33 Posted August 12, 2016 Here is mine, but it is a 1972. This seat, one of Scott's horses, is another common seat to the Raiders. Share this post Link to post Share on other sites
Anglo Traction 761 #34 Posted August 12, 2016 Hi, Your Tractor is unlikely to be earlier than 1973. It has the later PTO Control and the Hood Decals introduced that year. The seats were usually sourced from the UK, as was your Steering Wheel. Your seat would have looked like mine on this 1974 12hp (Belgium Assembled)- Pre 1972 Decals looked like this (also note the same steering wheel as yours- The Seats are still available new HERE if you wish to obtain one from the UK....may also be available in the Netherlands?. 1 Share this post Link to post Share on other sites
ikbendennis 3 #35 Posted August 12, 2016 That's a nice tractor that you have my tractor is from 1971 I will look for that seat here in the Netherlands Share this post Link to post Share on other sites
ikbendennis 3 #36 Posted August 13, 2016 and what for kind oil do u guys use for the transmission and the engine ?? Share this post Link to post Share on other sites
stevasaurus 23,812 #37 Posted August 13, 2016 90 wt in the trans...30wt in the engine Share this post Link to post Share on other sites
ikbendennis 3 #38 Posted August 18, 2016 my wheel hub is fixed !! we have made one out of a car axle shaft 2 Share this post Link to post Share on other sites
Achto 32,443 #39 Posted August 19, 2016 Very nice job! Your new steel hub will probably out last the cast one by far. 1 Share this post Link to post Share on other sites
