Uncle Buck 246 #1 Posted August 3, 2016 Any guys really into Wisconsin engines, or perhaps simply know a lot about them? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,600 #2 Posted August 3, 2016 I have one on the Sr. I can help you with cleaning the carb.....Jeff (fireman) has a pretty good understanding of the internals on them. What do you need help with? Share this post Link to post Share on other sites
Uncle Buck 246 #3 Posted August 3, 2016 Is it against the rules to show a you tube link of what I have here? I did not put it on you tube either but it shows what I am working on. If I cannot do that can I PM you with it? Share this post Link to post Share on other sites
AMC RULES 37,250 #4 Posted August 3, 2016 Youtube links are OK here. Share this post Link to post Share on other sites
Uncle Buck 246 #5 Posted August 3, 2016 I am going to hope that I am not breaking any rules and apologize for my mistake if I did break a rule. Attached is a link to the kind of setup I am working on. The guy in the link claims his Wisconsin engine is an AHHD which I believe is incorrect. I think his engine is an AHH and I think my engine is the same model number. Unfortunately for me the aluminum data plate with the model number, serial number etc. that Wisconsin usually affixed to their engine shrouds is missing from mine. Worse, my engine is missing the carburetor. The only important difference between the unit shown in the You Tube link and my machine is that machine has a two stage V compressor pump and mine is a single stage pump of roughly the same large dimensions as the one shown in the link. So far I have contacted DeVilbiss technical support to see if they might have some info that could help confirming my engine is an AHH. Now I am asking the brain trust here if there is an answer to be confirmed. So if you can confirm for me that the engine in the link is an AHH that would be the first step to replacing my missing carburetor. Thank you for any help you might be able to supply. Share this post Link to post Share on other sites
WHX?? 53,360 #6 Posted August 3, 2016 Cool Uncle Buck and thanks for sharing... I trust you did some other web based searches on Wisconsin engines. Should be quite abit of info on them in cyber land. I thought at one time in my quest for Clinton info I ran across a antique power club that had some good poop/experts on them. I used to work on them abit but mostly the v-4's and pretty much forgot what little I did know. Hopefully others here can help you out with your project & good luck. Share this post Link to post Share on other sites
Uncle Buck 246 #7 Posted August 3, 2016 (edited) I know there is some good info to be found over at Smokstak but I seem to be having a tough time getting my membership confirmed so as to drill deeper into those resources. I want to make my unit sound as good as the one in the attachment first. Once I accomplish that I want to blow it all apart for a full blown orange, gray and black restoration. My unit looks way cooler than the one shown with its old timey 6.00 x 16 rim tires and it's factory tow hitch. Factory manual info is easily found as well. What is tougher is confirming for sure what model I have. I will be able to make headway faster once I know what I have and what kind of carb I need. Edited August 3, 2016 by Uncle Buck Share this post Link to post Share on other sites
