Adamsminitractor 9 #1 Posted August 1, 2016 Hi all. I have a 73 Raider 12 fitted with a 42" rear discharge cutter deck. I somehow lost my center blade, nut, spacer and cup. I am after a set of 3 blades as i might aswell change them all. I have ordered a set (i live in uk) for a 42" deck but they are about 1/2" shorter than the others and it says they fit the 36" and 42" rear discharge decks. My question is how to i know what cutter deck i have. And can anyone tell me part number i need. Also is the middle blade longer that the other 2? Cheers guys. This is a link i used to look blades up http://static.fatsoma.com/gts-pdfs/toro/decks-4.pdf Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,008 #2 Posted August 1, 2016 The first decks used blades with a 5/8" x 3/4" double-D center hole. Is that what you have? Later the blades have a 3/4" round hole. The 3 blades should be the same length for a 42" deck. The 36" decks use a center blade that is 2" longer than the outside blades. Decks are sized by their width of cut. Garry Share this post Link to post Share on other sites
Adamsminitractor 9 #3 Posted August 1, 2016 6 hours ago, gwest_ca said: Hi ya Garry. My deck is 42" across and the blades have a single 3/4 inch hole in the middle. My center blade has somehow got lost so have no clue if its longer or not. The blades that are on there now are 14 1/4" long (the outside ones) the middle blade is gone so have no clue what size it is ment to be. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,008 #4 Posted August 1, 2016 The first 42" rear discharge deck to use blades with a 3/4" center hole was a 1977 model 75-42MR02 The model 75-42MR01 used blades with the double-D center hole. The deck you have could be anything from 1977 till the end of production. A bit more http://www.wheelhorseforum.com/search/?type=downloads_file&q=75-42MR02 The blades come from Toro as a 3-blade set but other suppliers sell them individually. Garry Share this post Link to post Share on other sites
