Farmitall 26 #1 Posted July 31, 2016 Hi, I am looking for a shallow oil pan that will fit a 10hp Kohler K241AS engine that originally came out of a 1965 Wheel Horse 1075. If anyone knows where I can get one of these or who has one, it would be appreciated. Share this post Link to post Share on other sites
Racinbob 12,644 #2 Posted July 31, 2016 Use caution here. If you're talking about the shallow oil pan that was used on the late 70's wobble mount motors it won't bolt up to that block. 1 Share this post Link to post Share on other sites
Farmitall 26 #3 Posted July 31, 2016 The shallow oil pan I am looking for is from the mid 1960's, because the tractor it came out of was made in 1965. Share this post Link to post Share on other sites
Shynon 7,533 #4 Posted July 31, 2016 Cast iron pans are available on I have bought one from a cub and loctited in the drain plug on the bottom of the pan then ground it flush, will need to drill and tap a drain hole on the appropriate end of the pan. 1 Share this post Link to post Share on other sites
Farmitall 26 #5 Posted July 31, 2016 Ok, thank you. I will look into it. Share this post Link to post Share on other sites
rmaynard 16,837 #6 Posted July 31, 2016 The pan for your engine is a shallow pan and the Kohler part number is 236265-S. However, it is no longer available. You may be able to find one used on eBay, but I haven't seen one recently. Good luck in your search. 1 Share this post Link to post Share on other sites
Farmitall 26 #7 Posted July 31, 2016 Yeah, i have been looking for that oil pan for a while. Thanks for the information. Share this post Link to post Share on other sites
