Swine_10 0 #1 Posted July 28, 2016 I just bought a 318-8 with a RD deck and replaced the spindle belt because there was a grinding. Thought it would fix the problem because the belt was in rough shape. It still makes a grinding noise coming from one of the spindles. Would it be the bearing in the spindle or ?? Share this post Link to post Share on other sites
Ed Kennell 45,027 #2 Posted July 28, 2016 When you had the deck belt off, did you check each spindle for noise, side (radial) and vertical(axial) movement? Radial movement of a shaft or pulley is a sure indication the bearing is worn. Any grinding noise or friction means it has disintegrated. Also check the idler tension pulley for noise and movement. Mule drive and PTO bearings can also cause noise. Check them all with the belt off. And to the 1 Share this post Link to post Share on other sites
russellmc301 601 #3 Posted July 28, 2016 add some oil and it might fix the problem Share this post Link to post Share on other sites
Wheel-N-It 2,978 #4 Posted July 28, 2016 32 minutes ago, russellmc301 said: add some oil and it might fix the problem Probably too late , grease the problem spindle with about 10 shots of light quality grease. Which spindle is it? Is it the center one? Very important to know. Share this post Link to post Share on other sites
Swine_10 0 #5 Posted July 28, 2016 (edited) I greased and oiled all the pulleys really well and still makes the grinding noise. With the belt off I spun all the pulleys and the far left pulley is only making the noise. Also the tensioner pulley seems to rub on the tension bar right below it (with the belt on). Edited July 28, 2016 by Swine_10 Share this post Link to post Share on other sites
Wheel-N-It 2,978 #6 Posted July 28, 2016 Sounds to me like it's bearing replacement time, at the least Share this post Link to post Share on other sites
Swine_10 0 #7 Posted July 28, 2016 Is it a tough task to replace the bearings? How much do you think they cost around? Share this post Link to post Share on other sites
Wheel-N-It 2,978 #8 Posted July 28, 2016 3 minutes ago, Swine_10 said: Is it a tough task to replace the bearings? How much do you think they cost around? Wish I could tell you exactly, but I've never had to do any work on the spindles on any of my decks since I bought my first wheel horse in 1991. I grease the deck before each use with LE grease. Share this post Link to post Share on other sites
Thisguyisnew 114 #9 Posted July 28, 2016 I currently have no issues but am fairly confident I could handle a bearing replacement. Does anyone know what's a good inexpensive brand or equivalent size just for future reference. Share this post Link to post Share on other sites
wrightorchid 261 #10 Posted July 28, 2016 (edited) The spindles and bearings are available, but a pain to do, and can be pricey. There are various threads already on here, with lots of pictures. There is one called 48" SDD that has a full deck rebuild that is pretty interesting. Edited July 28, 2016 by wrightorchid 1 Share this post Link to post Share on other sites
daveoman1966 3,882 #11 Posted July 28, 2016 Replace the whole spindle.... I just sent a PM regarding this option. my direct email is: daveoman@windstream.net Share this post Link to post Share on other sites
