Cmyers3843 1 #1 Posted July 21, 2016 I have a 1987 wheel horse 212-6 model number 3212k601. I put a new starter on it because the old ones bushings were bad. The old starter u turn the key and get a click every time and eventually u turn the key and the starter would activate. I put the new starter on and now it only clicks.any ideas 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,499 #2 Posted July 21, 2016 Here is a wiring diagram. What is clicking? Solenoid? Garry Share this post Link to post Share on other sites
953 nut 60,128 #3 Posted July 21, 2016 With any electrical problem the first step is to inspect, clean and tighten all connections including grounds. Following this you can take a jumper cable from the battery "+" directly to the starter terminal to be sure the starter will turn. Next take a small jumper from the battery "+" to the small terminal on the solenoid to see if it closes. 4 Share this post Link to post Share on other sites
cleat 7,260 #4 Posted July 21, 2016 My 111-6 would just click a lot then finally roll over and start. Replaced the solenoid and it is now good. Share this post Link to post Share on other sites
muz123 1,192 #5 Posted July 22, 2016 (edited) Join the 200 series clicking issue club. I've had a 212 for years and replaced all electrical items and still clicks a few times before starting. Edited July 22, 2016 by muz123 Share this post Link to post Share on other sites
woodchuckfarmer 333 #6 Posted July 22, 2016 Take your battery and have it tested, see if it is in good shape. 3 Share this post Link to post Share on other sites
Cmyers3843 1 #7 Posted July 22, 2016 (edited) I let it sit for a bit and the starter moved a tiny bit. I'm going to try and jump the battery to see if it's has low volts does anyone have pictures of the starters wires hooked up to the bottom of the starter Edited July 22, 2016 by Cmyers3843 Share this post Link to post Share on other sites
953 nut 60,128 #8 Posted July 22, 2016 Here is the manual for your engine, should provide answers to all your questions. Share this post Link to post Share on other sites
