ranjuro 0 #1 Posted July 20, 2016 First off, hi! I'm a new owner of a 1993 Wheel Horse 520H. The WH is solid, does a great job, starts fine... if I hook it up to jumper cables and a battery. Often, most of the time, it doesn't start without the jump. I've ruled out the battery, I've tried several, new, fully charged, no dice. The specific behavior is as follows. Turn the key into aux position, all lights on dash light up and then turn off. No issues. Turn key to start and there is a click and everything goes dead. Fuses are fine. Subsequent attempts are totally dead, dash lights don't even come on. Take a pair of jumper cables, hook 'em up to the terminals, and it goes back to normal and starts just fine. Drive it around a bit and there is a 50/50 chance it starts again when I stop it. I've been disconnecting the terminals when it's not in use and verifying that the battery is happily charged before attempting to start, but it makes no difference. I'm getting sick of jumping it. Seems like something shorting related to the solenoid, but any pointers or advice would be appreciated. Thanks! Ryan Share this post Link to post Share on other sites
Achto 30,887 #2 Posted July 20, 2016 28 minutes ago, ranjuro said: I've ruled out the battery, I've tried several, new, fully charged, no dice. Are your battery cables making good contact with the battery? Do you have a meter to monitor battery voltage while you are cranking the motor? If battery voltage does not decrease while trying to crank then I would say there is a connection issue. If voltage drops below 9v while cranking then you have either a poor battery or an excessive draw. Seems strange that it will start with a jump but not off a new battery. Share this post Link to post Share on other sites
Lane Huls 146 #3 Posted July 20, 2016 To me that screams connection at the battery like crazy. 1 Share this post Link to post Share on other sites
ranjuro 0 #4 Posted July 20, 2016 Battery connection looks clean, not corroded, nice and tight. When I turn the key to aux and all the dash lights are on, the gauge for battery charge level looks good. But then I turn the key to start it, the solenoid makes a click, and the whole system shuts down. I clip cables on from my little jump starter and it works perfectly. It is very strange. I found this post that sounds suspiciously like what I'm seeing:http://www.doityourself.com/forum/outdoor-gasoline-electric-powered-equipment-small-engines/425699-toro-wheel-horse-has-me-stumped.html#post1732146 I'm curious about the whole engine to frame ground. I think I will investigate that and see what I find out. Share this post Link to post Share on other sites
Lane Huls 146 #5 Posted July 20, 2016 Yeah, check all your connections. The battery connections are only two. Check your battery ground wire, check your connections at the solenoid. If the solenoid clicked but the whole system stayed on id say bad solenoid, but since its "shutting down" everything you are totally losing power. Which is typical of a bad connection somewhere. Share this post Link to post Share on other sites
DougC 2,643 #6 Posted July 20, 2016 Remove both battery cables from the battery. With a wire brush clean the entire battery terminals and cables where they contact each other. Just because they look ok does not mean they are making good enough contact with each other. the added draw of the starter motor is enough to make what little contact you have for the dash lights to work cease. Start at the battery since all is fine when you jump it at the battery. And to the forum!!! Share this post Link to post Share on other sites
N3PUY 1,031 #8 Posted July 20, 2016 Also check the fuse block and check to see if it still has power in and out of the ignition switch when this happens. 1 Share this post Link to post Share on other sites
new horse 44 #9 Posted July 20, 2016 I have a 520-H and was having similar starting issues, I usually had to jump the starter relay to get mine to start, it turns out one of the wires in the plug on the back of the ignition key switch was coming out of the plug, and only making "occasional contact" pushed the wire/terminal back into the plug and I haven't had any starting issues since Share this post Link to post Share on other sites
Digger 66 3,523 #10 Posted July 20, 2016 5 hours ago, ranjuro said: First off, hi! I'm a new owner of a 1993 Wheel Horse 520H Congrats & welcome to Red Square Share this post Link to post Share on other sites
cleat 8,723 #12 Posted July 21, 2016 (edited) I had an old Crown Vic do the exact same thing. Battery cable connections were the culprit. Take all connections apart, (battery, solenoid, ground, ignition switch) clean them and you should be good. Also make sure the fuse holders are clean as well. I know I am just repeating what was said, just reaffirming that this must be the problem. Edited July 21, 2016 by cleat Share this post Link to post Share on other sites
ranjuro 0 #13 Posted July 22, 2016 Thanks for the warm welcome! I'll be working on this Saturday morning and I'll definitely be using your suggestions as my guide. So great that there is such a great resource for a newbie! I'm looking forward to years as a Wheel Horse owner and it's a relief to know you guys are here. I'll post some pics and an update when I have one! Thanks again! Share this post Link to post Share on other sites
