seven 202 #1 Posted July 20, 2016 Is there anyway way to stop it from going back in all the time other than a vice grips Share this post Link to post Share on other sites
pfrederi 20,680 #2 Posted July 20, 2016 As I have time and money I try to convert to the lever style throttles. Fixes on the others always seem to give way after a short time. In the interim this redneck fix works and is cheap...one clip = fast idle 2 clips = mowing speed. 5 Share this post Link to post Share on other sites
Achto 31,916 #3 Posted July 20, 2016 32 minutes ago, seven said: Is there anyway way to stop it from going back in all the time other than a vice grips If it creeps in even after turning the knob clock wise to tighten it, then replacement is the only good cure. I got an aftermarket one from pesp.biz and it has been working great for me. ROT9135 is the part number about $9 3 Share this post Link to post Share on other sites
seven 202 #4 Posted July 20, 2016 I found one on eBay 9135 to replace wheelhorse it is a push/ pull with lock 14 dollars? Share this post Link to post Share on other sites
Achto 31,916 #5 Posted July 20, 2016 35 minutes ago, seven said: I found one on eBay 9135 to replace wheelhorse it is a push/ pull with lock 14 dollars? Should work. Just make sure that it is long enough for the job, you can make them shorter if needed but you can't make it longer. 1 Share this post Link to post Share on other sites
oldredrider 2,553 #6 Posted July 20, 2016 1 hour ago, achto said: Should work. Just make sure that it is long enough for the job, you can make them shorter if needed but you can't make it longer. That's what she said! 5 Share this post Link to post Share on other sites
Achto 31,916 #7 Posted July 20, 2016 15 minutes ago, oldredrider said: That's what she said! Totally missed that when I typed it out, good catch! LOL 2 Share this post Link to post Share on other sites
seven 202 #8 Posted July 20, 2016 I'm glad ya all got some humour 1 Share this post Link to post Share on other sites
WHX?? 56,862 #9 Posted July 20, 2016 No fair Old Red that's my saying!!! 1 Share this post Link to post Share on other sites
Bigfish 146 #10 Posted July 21, 2016 Didnt the older style pull throttle have a twist to lock function? The 875 i have kept doing the same thing then i pulled it out and twisted it clockwise about 2 turns. 1 Share this post Link to post Share on other sites
seven 202 #11 Posted July 21, 2016 Ya that's how mine is it says it rite on the knob to turn to hold but the vibration takes over and it moves in.its a common problem Share this post Link to post Share on other sites
