buffaloman 295 #1 Posted July 18, 2016 My father in law recently purchased a GT -14 ,Over the weekend was my first time operating it .I thought it seemed fine while mowing but when I stopped at the bottom of the barn hill and tried to go up it ,it just would not do it . Im hoping this is just a slipping belt ???? Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted July 18, 2016 Make sure the "Tow-Valve" is closed. Share this post Link to post Share on other sites
daveoman1966 3,882 #3 Posted July 18, 2016 More than likely, the GT-14 has a worn out Sundstrand Hydrogear power unit model 90-2062....the only cure is a rebuild. I have rebuilt many of these and MAY be able to do the same for yours. If you want to pursue this, contact me at the following email address so I can provide cost and timing estimates. I am: daveoman@windstream.net Share this post Link to post Share on other sites
953 nut 64,263 #4 Posted July 19, 2016 32 minutes ago, buffaloman said: thought it seemed fine while mowing Was the engine running at near wide open throttle? If you moved the motion controller all the way forward did it take off? Have the fluid and filter been changed? How well did it operate in reverse? If you download the manual you will see a trouble shooting chart that could be helpful. Share this post Link to post Share on other sites
buffaloman 295 #5 Posted July 19, 2016 ok ,ill check these things out , my father in law has the books ill check them out too.thanks! Share this post Link to post Share on other sites
russellmc301 601 #6 Posted July 19, 2016 check the oil it might be low. 1 Share this post Link to post Share on other sites
