clueless
B-80 spindle?
clueless
Working on a '77 B-80, may need a front spindle one on the left when sitting on tractor is that the left or right side? What other tractor spindles will fit the B-80, also what size are the E-clips. Thanks, Chris.
gwest_ca
No easy way to tell any more what other models use the same part. Only 2 models listed here but suspect there should be many more. All you can do is check other parts lists for the C-Series and 300-Series. if you come up with a different part number run it to see if it is changed up to this part.
https://www.partstree.com/parts/toro/parts/115425/
Left and right are always from the operator's position and that goes for machinery and autos.
E-clips should be 3/4". They are sized to fit the shaft size - not the groove.
Garry
wallfish
Maybe best if you post some pics of the spindle with a tape measure showing the lengths of the shafts. Plus the pics will show clips or bolts and the Akerman arm.
I have some spindles around but have absolutely no clue if they fit your B-80 or not ( or any other particular tractor ). Probably the same thing with many other members too but doubt it's worth the time for us to do all the research to try and find out, if that's even possible. BUT, I have no problem at all going out to quickly measure them to see if one will work for you!
It's certainly possible someone has a B-80 they're parting out and would have one but...
Just say'n this might be quicker
E-clips are for 3/4 shaft
