Elroy Heselton 3 #1 Posted July 14, 2016 (edited) I picked up a 4 speed transmission at the big show. It has 1'' axles and there is 2 1/2'' of axle showing between the hubs and the transmission housing, I'd like to know what this came out of. It is just a regular transmission case with 2 1/2'' of axle showing before the hubs. There is nothing different about it to see. A picture isn't going to show anything different. Edited July 15, 2016 by Elroy Heselton Share this post Link to post Share on other sites
Achto 31,109 #2 Posted July 14, 2016 I'm not a tranny expert but there are a lot of guys on here that will be able to tell you what it is from a pic. Share this post Link to post Share on other sites
953 nut 64,263 #3 Posted July 15, 2016 Are there any numbers you can give us? And yes, pictures would be helpful. Share this post Link to post Share on other sites
JC 1965 1,543 #4 Posted July 15, 2016 Hello and and Share this post Link to post Share on other sites
Racinbob 12,798 #5 Posted July 15, 2016 A couple of pictures would help. There are variations in the 3&4 speed transmissions. Are the ends of axles flush with with the outside of the hubs? Pull the hubs off and measure how much axle sticks out. . Share this post Link to post Share on other sites
stevasaurus 23,619 #6 Posted July 15, 2016 (edited) If it is a 2 piece transmission case, it depends on where the brake drum shaft comes out. If it is the hole closest to the axle, it is a 3 speed unidrive...5007, 5025, etc. If the brake drum comes out the next hole toward the front of the transmission, it is a 4 speed unidrive...5080, etc. The bevel gear differential has 1 1/8" axles. Edited July 15, 2016 by stevasaurus Share this post Link to post Share on other sites
Racinbob 12,798 #7 Posted July 15, 2016 I just wanted to lay an eyeball on it Steve. My second thought, after the hubs not being all the way on, was that he may have bought a 5045 for a 953. Aren't those axles longer? But....I think they are `1 1/8" so that would be out. 1 Share this post Link to post Share on other sites
stevasaurus 23,619 #8 Posted July 15, 2016 Right Bob. You know what, I read it wrong. I thought he was talking about how much axle was sticking out, not how much axle he has showing between the hub and the axle. My bad. Everything I said above is correct for what I said, but he has a four speed transmission that has the longer axles like for the 1972 commando 800. The trans is a #5085. My tunnel vision would not have happened with a picture...not Elroy's fault. The fault is mine. Just getting old. Share this post Link to post Share on other sites
Elroy Heselton 3 #9 Posted July 15, 2016 This transmission does have the brake in the forward hole, 2'' axles, 2 1/2'' axle space between the hubs + transmission ends. Hubs are at the ends of the axles. Like Stevasaures said, the #5085 was used on the Commando 800 - 1972+1973 and on the Raider 12 -1974 . Was this a 4 pinion rear end? I want to thank you guys for all your help. This transmission is bolted to a Commando 8 short frame, Suburban front axle, fender- seat assy-653, B 60 steering + dash, home made frame to dash mount. 16x 6.50 -8 front tires, 23x10.50- 12 rears. I have to get a late 60's hood and a K321 engine. Thanks again Elroy 1 Share this post Link to post Share on other sites
stevasaurus 23,619 #10 Posted July 16, 2016 Yes, it is a 4 pinion differential. How about some pictures of that horse when you get it together?? sounds interesting. Share this post Link to post Share on other sites
