scotty 252 #1 Posted July 13, 2016 I just bought a 416h wheel horse im fixing up and it needs a drive belt does anyone know the length? It has an onan on it if that matters. Share this post Link to post Share on other sites
Jerry77 1,218 #2 Posted July 13, 2016 I came up with toro part no. 7473 - at Jacks engines..cheaper on ebay tho - $15.13 at V-belt guys....I bought one from then a month ago for my 516h and it fit perfect . belt should be 82 inches....good luck Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,770 #3 Posted July 13, 2016 1989 was the first 416 with an Onan twin cylinder which uses a different belt that the Kohler single cylinder models. Tractor drive belt 107939 replaced by 93-9809 - (HB x 83.5" or 5/8" x 83-1/2") This belt was later replaced by 79-2500 which is 1/2" shorter - HB x 83" or 5/8" x 83" Garry Share this post Link to post Share on other sites
Jerry77 1,218 #4 Posted July 13, 2016 Believe the model 73421 is a two cylinder 16hp Onan, according to:http://www.mywheelhorse.com/graphics/file/wheel_horse_products_master_model_list.pdf ?? which publication is correct? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,770 #5 Posted July 13, 2016 1 hour ago, Jerry77 said: Believe the model 73421 is a two cylinder 16hp Onan, according to:http://www.mywheelhorse.com/graphics/file/wheel_horse_products_master_model_list.pdf ?? which publication is correct? What model number and serial number are you using to get a parts list? Possibly it is one shared with the 8-speed model and if so both belts should be in the parts list but often not identified as what model uses what belt. 516-H Transmission drive belt 112801 replaced by 114895 - (HB x 82.95 or 5/8" x 82.95") Garry Share this post Link to post Share on other sites
Jerry77 1,218 #6 Posted July 13, 2016 http://www.ereplacementparts.com/toro-3116oe01-1988-lawn-tractor-parts-c-121776_128672_131927.html This is the place where I went to get the number for my belt ( 516H) it is in fact 114895 as you stated.. in the process of trying to be helpful, I dicombobulated the length of the belt - it is 5/8 x 83 inches - not 82 as I stated - here is a link for that belt on e-bay...thanks Garry for steering me in the right direction - sometimes my right is actually my left lol sorry about that Scotty http://vod.ebay.com/vod/FetchOrderDetails?itemid=371002264271&transid=829021306024&qu=1&ul_noapp=true it is cheaper than Jack's engines It just occured to me that the length on the belt for the eaton 700 and 1100 might be different ?? Share this post Link to post Share on other sites
scotty 252 #7 Posted July 13, 2016 No problem i appreciate all of the help guys! I actually have a new 5/8 x 83 kevlar belt on hand. Share this post Link to post Share on other sites
