scotty
416h drive belt length?
scotty
I just bought a 416h wheel horse im fixing up and it needs a drive belt does anyone know the length? It has an onan on it if that matters.
Jerry77
I came up with toro part no. 7473 -  at Jacks engines..cheaper on ebay tho - $15.13 at V-belt guys....I bought one from then a month ago for my 516h and it fit perfect . belt should be 82 inches....good luck
gwest_ca
1989 was the first 416 with an Onan twin cylinder which uses a different belt that the Kohler single cylinder models.
Tractor drive belt  107939 replaced by 93-9809 - (HB x 83.5" or 5/8" x 83-1/2")
This belt was later replaced by  79-2500 which is 1/2" shorter - HB x 83" or 5/8" x 83"
Garry
gwest_ca
1 hour ago, Jerry77 said:
Believe the model 73421 is a two cylinder 16hp Onan, according to:http://www.mywheelhorse.com/graphics/file/wheel_horse_products_master_model_list.pdf  ?? which publication is correct?
What model number and serial number are you using to get a parts list? Possibly it is one shared with the 8-speed model and if so both belts should be in the parts list but often not identified as what model uses what belt.
516-H
Transmission drive belt 112801 replaced by 114895 - (HB x 82.95 or 5/8" x 82.95")
Garry
Jerry77
http://www.ereplacementparts.com/toro-3116oe01-1988-lawn-tractor-parts-c-121776_128672_131927.html
This is the place where I went to get the number for my belt ( 516H)   it is in fact 114895 as you stated.. in the process of trying to be helpful, I dicombobulated the length of the belt - it is 5/8  x  83 inches - not 82 as I stated - here is a link for that belt on e-bay...thanks Garry for steering me in the right direction  -  sometimes my right is actually my left  lol sorry about that Scotty
http://vod.ebay.com/vod/FetchOrderDetails?itemid=371002264271&transid=829021306024&qu=1&ul_noapp=true  it is cheaper than Jack's engines       It just occured to me that the length on the belt for the eaton 700 and 1100 might be different ??
scotty
No problem i appreciate all of the help guys! I actually have a new 5/8 x 83 kevlar belt on hand.
