Biel 0 #1 Posted July 12, 2016 Hi, does anyone know where I can get front wheels for a 1961 401 suburban, of wheels that will work with that off set? thanks Biel Share this post Link to post Share on other sites
Achto 31,068 #2 Posted July 12, 2016 Unfortunately a lot of the original wheels for those things fell victim to calcium chloride. They filled the front tires with it from the factory for weight. While it gets along great with rubber, it loves to eat metal . So if you had a leak in the tube your rim would start corroding shortly there after. Most are reluctant to let go of a good set of rims, but if you are patient you may find a pair. You could also use a newer set of 8" rims and add spacers to the axle to make up for a narrower hub if needed. Share this post Link to post Share on other sites
WHX?? 55,117 #3 Posted July 12, 2016 and keep an eye or search the classifieds... maybe throw an add in wanted Share this post Link to post Share on other sites
Biel 0 #4 Posted July 12, 2016 Thanks guys, I appreciate the help! Share this post Link to post Share on other sites
Biel 0 #5 Posted July 12, 2016 Back again sorry, I found a pair of wheels from a C120 do you think they will work? thanks again Share this post Link to post Share on other sites
RedRanger 1,470 #6 Posted July 13, 2016 I found a pair on ebay. Seller had them listed as "old tractor rims". Share this post Link to post Share on other sites
Biel 0 #7 Posted July 13, 2016 Thanks everyone for the help! Share this post Link to post Share on other sites
