Kelly 1,038 #1 Posted December 23, 2008 I think I know the answwer to my own question but I'm going to ask anyway, while blowing snow with my C-141 not sure what model blower but from the 70's, the shoot turns back straight, anyone else have this problem? I screwed up and lightly oiled everything so it turns smooooooth but now it won't stay put I'm thinking of adding a washer or 2 under the spring on the turning handle to tighten it up a bit, what do you guys think?? :hide: Share this post Link to post Share on other sites
GlenPettit 1,719 #2 Posted December 23, 2008 Kelly: The Spring in the middle of the turning bar is supposed to add the tension to reduce it from turning on its own, also, when wrapping the turning cable we start from front center & try to make it taunght (done on a very warm day so the heat has stretched it already)(the movement & bumping of the snow & chute & loose cable makes the chute turn). Can the four bolts holding the chute base/washer in position be tightened? The chute does seem to want to change directions on it's own, I have to use a bungee cord (handle to center) when blowing with the chute to the far left. Good Luck, Glen Share this post Link to post Share on other sites
WheelHorse_of_course 101 #3 Posted December 23, 2008 :hide: mine doesn't turn because it has no cable. It is held in place with a piece of coat hanger I have not gotten to try it yet - all the snow keeps missing us so we have not gotten more than an inch at a time. I figure when we do get some sonow I will just make the wind shift directions instead of turning the shoot :omg: Share this post Link to post Share on other sites
