Nhaydt92 35 #1 Posted July 10, 2016 I've got a sickle bar for my 702 the other week. Turns out the guy I bought it from didn't tell me that the bearings in the carriage part were shot. So I'm looking for them and also the gearbox seems to be leaking a decent amount of fluid. Would it be the cover plate on the side or from the shaft where the wobble things connected. Also all the teeth are in great shape except one of the things that slide side to side that's riveted on is chipped, can you replace them yet too? Share this post Link to post Share on other sites
MalMac 1,332 #2 Posted July 11, 2016 The carriage bearings are Toro 99-5379 On Zoro web siite https://www.zoro.com/tritan-insert-ball-brng-uc-78in-dia-314733-lb-uc205-14/i/G2096976/?KW2&gclid=CMGx6Ziw680CFQIRaQodrIYA4w&gclsrc=aw.ds As far as your oil leak it could be from ether one. Gasket on side plate could be bad or the oil seal on the shaft. The 1 1/4" shaft seal is Toro 103118 the 1" seal is Toro 100863 Share this post Link to post Share on other sites
Nhaydt92 35 #3 Posted July 11, 2016 Thank you very much!! Share this post Link to post Share on other sites
