Dave85zxt 0 #1 Posted December 22, 2008 Hi Guys, I just tried my recently rebuilt snowblower for the first time and found out that tractor is a little too fast in 1st gear. It does just fine with light snow but it can't handle 6"+ of the heavy stuff because the tractor is moving too fast. I don't like the idea of riding the "clutch" all the time because its just going to wear out the belt. Has anyone tried increasing the size of the rear drive pulley on the transmission to slow down the tractor? Its easy enough that I don't mind doing it twice per year (high speed for summer and low speed for winter). Thanks, Dave Share this post Link to post Share on other sites
kpinnc 17,616 #2 Posted December 23, 2008 Hey Dave, Lots of people have played with pulley sizes to adjust ground speed. But, you won't have much room to work with before the rear of your belt guard will become an issue. Other than that (and additional belt length), it will be fine to put a larger pulley on the tranny. Kevin Share this post Link to post Share on other sites
Teddy da Bear 11 #3 Posted December 23, 2008 I take it you have a manual tranny? Why not put it in low 2nd gear? That should be slow enough. Share this post Link to post Share on other sites
kpinnc 17,616 #4 Posted December 23, 2008 Why not put it in low 2nd gear? That should be slow enough. 856 tractors did not have low range. Kevin Share this post Link to post Share on other sites
htopjimmy26 3 #5 Posted December 23, 2008 Does an 856 have ranges? :hide: Share this post Link to post Share on other sites
htopjimmy26 3 #6 Posted December 23, 2008 gotta love simultaneous replies :hide: Share this post Link to post Share on other sites
WheelHorse_of_course 100 #7 Posted December 23, 2008 Another approach would be to take a narrower swath after riding the clutch on the first pass. Share this post Link to post Share on other sites
Teddy da Bear 11 #8 Posted December 23, 2008 OOOPS!!! Am I bad? Did not read his signature...... Sorry for the fauxpah. Share this post Link to post Share on other sites
Dave85zxt 0 #9 Posted December 23, 2008 Thanks for the feedback guys. I am not concerned with pulley interference with the belt guard. I have enough fabrication skills to take care of that. I wish I had a low range though. I don't suppose that any of the low range trannies would retrofit to an 856? Share this post Link to post Share on other sites
rustbucket 4 #10 Posted December 23, 2008 i know off hand that wheel horse made a speed reduction kit for theit machines and all it consisted of was a new belt guard a way larger tranny pully and double idler/tenssioner pullies under the bel guard. reason i know this is one of my rund noses has the kit already instaled and i have the paperwork on it laying around somewhere at hand. Share this post Link to post Share on other sites
Teddy da Bear 11 #11 Posted December 23, 2008 Now there is an idea! Might be easier to swap trannys for winter than just a pulley. I might have heard of doing this before. Bolts might not line up....just drill a couple extra holes for alignment. But someone more experienced will be able to tell you if it is feasible for your specific model. Share this post Link to post Share on other sites
kpinnc 17,616 #12 Posted December 23, 2008 I don't suppose that any of the low range trannies would retrofit to an 856? I have an 867, which is virtually identical to an 856 except for one thing- It has an 8 speed tranny... It would be an easy fix. Just depends on how original you plan to keep your machine. Good luck! Kevin Share this post Link to post Share on other sites
Rollerman 290 #13 Posted December 23, 2008 You could put a slightly smaller pulley on the the engine for the drive only? The one on the left of the pic came with a Lawn Ranger...not sure it's an OEM item, but I'm guessing a PO may have been expeirmenting? You may want to check the back tires too. Slightly smaller diameter or less air pressure may make a little differance. Share this post Link to post Share on other sites
69DEZ 6 #14 Posted December 23, 2008 By no means am I a blower expert. BUT I was having the same issue that you are describing. My first cut is in 1st gear. When it looks like the stream is slowing down I lift up the blower a little and let it catch up and continue my cut. 2nd pass half the blower with in 2nd gear. You have to keep a steady stream. If it's an interrupted cut it will clog. I know it doesn't make much sense, but I couldn't believe how well it worked. NIGHT AND DAY DIFFERENCE. 1st gear 2nd gear :horseplay: :horseplay: :horseplay: Also new belts make a big difference. Not bad for a VERT Share this post Link to post Share on other sites
Dave85zxt 0 #15 Posted December 23, 2008 I don't have lift control on the old 856. It would be a nice feature. Maybe I could reg something up. Share this post Link to post Share on other sites
