Huntemcd
Vertical shaft Tecumseh.
Huntemcd
Will a horizontal shaft starter inchange with a vertical shaft.
what motors?    i have a starter from a V70 on a H60
Huntemcd
Idk. All I know is it's a vertical shaft 8 horse tecumseh.
Huntemcd
So would a horizontal starter work for a vertical. They should be about the same year of motors. But the horizontal is a 7hp
you could take the model numbers and type numbers of both motors , then go the Partstree.com and look up a starter for both motors and see if they are the same part number...or maybe one part number supersedes the other
or you could just do it the old fashion way....  give it a try.  compare the two starter motors first
FYI...a V70 is a vertical motor and the H60 a horizontal
Huntemcd
Ok thanks. I don't know tecumsehs thing. I only know Kohler because that's what all of our wheel horses have.
