cod 121 #1 Posted July 4, 2016 Looking for suggestions on trying to diagnose a hot starting problem. The 418A starts fine when cold and the ampmeter indicates that the battery is charging. I run the tractor for a couple of hours cutting grass and then I'll park it and shut the motor off to blow grass cuttings out of all the nooks and crannies. When I hop back on the tuck the beast in for the day, turning the key does nothing. No sounds and no crank. If I turn the key to run and jump across the solenoid the engine fires right up and off we go. I realize that by "assuming" the cold start means everything is okay I'm missing something so before I start pulling the electrical system apart and cleaning every connection I can find, are there any pointers as to what might be causing this to be a reoccurring problem. The battery voltage cold (no motor running) is 12.7 and I believe with the motor running it's just over 13. Thanks - Cod Share this post Link to post Share on other sites
SylvanLakeWH 28,847 #2 Posted July 4, 2016 Check that you completely disengage the PTO handle when you stop mowing. I have had the same thing happen two times and found it was just the PTO handle did not stay / get completely disengaged. Now I just purposely / firmly disengage and no issue. Just a thought... 1 Share this post Link to post Share on other sites
cod 121 #3 Posted July 8, 2016 Thanks Sylvan for the tip but I finally found it! The start switch has a sweet spot and if I turn it "just right", it fires right up. I tested the wires from the switch to the solenoid and all of them checked out fine. It was only when i was fiddling with the switch itself that I found out. Shame they wear out so quickly. Might have to look into converting a older car ignition switch as they seem to last longer. Cod 3 Share this post Link to post Share on other sites
Tuneup 1,452 #4 Posted July 11, 2016 At least the switch can be disassembled and cleaned. If you have the PTO switch I have on the C-125, same. I had the exact problem and it was that switch. A little TLC and she's back running again. Glad you found it. Electrical can be a bother! 1 Share this post Link to post Share on other sites
