erwine13b 27 #1 Posted July 4, 2016 my 310-8 fires on the first few cranks when cold no problem barely have to choke, but when the engine is hot it cranks and cranks then spits out black smokes and sputters to full rpms. Any ideas on what could could be causing this? i know you guys are like a book on this forum. Share this post Link to post Share on other sites
Digger 66 3,488 #2 Posted July 4, 2016 Choke butterfly opening all the way ? 2 Share this post Link to post Share on other sites
squonk 44,900 #3 Posted July 4, 2016 Float level, mixture setting. Your engine is getting way too much fuel. That's why it starts right up when cold with little choke. 8 Share this post Link to post Share on other sites
wallfish 18,791 #4 Posted July 4, 2016 Black smoke is excess un-burnt fuel. 2 Share this post Link to post Share on other sites
prondzy 3,889 #5 Posted July 4, 2016 Clean the carb and lean it out a little Share this post Link to post Share on other sites
erwine13b 27 #6 Posted July 6, 2016 so basically you guys are telling me i need to adjust he carb a little? sorry dont know the lingo lol and tyvm gentlemen Share this post Link to post Share on other sites
Tuneup 1,452 #7 Posted July 6, 2016 Hi erwine, She's clearing her throat from excess fuel when warm. Hey, it's just an opportunity to spend some time with your machine. It wants some lovin'. There are the usual checks - choke stuck in the ON position - very dirty air cleaner. Was the carb adjusted when the engine was cold? Was it adjusted with the air filter removed? Warm it up and adjust the carb and then see if it clears. If not, pull the carb and clean it - solvent and compressed air through the passages. Don't get any solvent on the gaskets. With today's fuel quality, you might find some trash in the bowl.The float is an on/off valve for the fuel level and the level is too high the engine will be rich so it's good to get in there and verify the adjustment and to ensure that the valve (needle and seat) isn't clogged or dirty. Once you have it clean and the float adjusted to the right level - the manual for the Magnum 10 is on this forum - put her back on there and adjust it when warm. 4 Share this post Link to post Share on other sites
wrightorchid 261 #8 Posted July 6, 2016 Check your fuel lines, tank, and filters, since these can cause havoc also. I cleaned up a carb, only to have trash in the tank clog the lines. Share this post Link to post Share on other sites
erwine13b 27 #9 Posted July 6, 2016 4 hours ago, Tuneup said: Hi erwine, She's clearing her throat from excess fuel when warm. Hey, it's just an opportunity to spend some time with your machine. It wants some lovin'. There are the usual checks - choke stuck in the ON position - very dirty air cleaner. Was the carb adjusted when the engine was cold? Was it adjusted with the air filter removed? Warm it up and adjust the carb and then see if it clears. If not, pull the carb and clean it - solvent and compressed air through the passages. Don't get any solvent on the gaskets. With today's fuel quality, you might find some trash in the bowl.The float is an on/off valve for the fuel level and the level is too high the engine will be rich so it's good to get in there and verify the adjustment and to ensure that the valve (needle and seat) isn't clogged or dirty. Once you have it clean and the float adjusted to the right level - the manual for the Magnum 10 is on this forum - put her back on there and adjust it when warm. tyvvvvvvvvvvm tuneup i'll follow this to the T and post back the results everyone that commented is awesome! Share this post Link to post Share on other sites
erwine13b 27 #10 Posted July 11, 2016 carburaer was problem sorr m keboards broke lol some kes don work haha, he carb jus needed adjusing 2 Share this post Link to post Share on other sites
Tuneup 1,452 #11 Posted July 11, 2016 So glad you got her running! Keep the keyboard - fun reads. 3 Share this post Link to post Share on other sites
erwine13b 27 #12 Posted July 12, 2016 On 7/11/2016 at 6:49 AM, Tuneup said: Keep the keyboard - fun reads. haha anoher hing ive noiced is i have air bubbles in he hose under he carb when is warm, how bad is ha ? Share this post Link to post Share on other sites
lynnmor 8,266 #13 Posted July 13, 2016 There is no hose under the carb. The fuel hoses are rubber, so you can't see bubbles anyway. Now ask about the fuel filter. Share this post Link to post Share on other sites
