ronhatch 410 #1 Posted June 30, 2016 (edited) I wondering if all non-electric clutch pulleys are the same diameter? I'm thinking about speeding up the deck RPM by installing a slightly larger clutch pulleys if some models came with a larger clutch pulleys then my C-101. It would be a lot easier to install a smaller driven deck pulley. I feel that pulley is already pretty small, but maybe, going down by a 1/2" diameter would still be OK?? I know I can't over speed the deck too much because of overloading the 10 HP Kohler. Comments please. . Edited June 30, 2016 by ronhatch Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,008 #2 Posted June 30, 2016 I'm pretty sure the drive pulleys are all the same size. Maximum blade tip speed is 19,200 feet per minute. What is the width of cut of this deck? Garry 1 Share this post Link to post Share on other sites
ronhatch 410 #3 Posted June 30, 2016 M C-101 has a 42" SD deck. I kinda figured that the clutch pulleys were all the same, but I though I would ask anyway. It just seems like all the newer mowers runs there blades a lot faster then our older tractors do. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,008 #4 Posted June 30, 2016 Have a photo tachometer? A 14" blade turning 5,238 rpm gives a blade tip speed of 19,200 feet per minute. Garry 1 Share this post Link to post Share on other sites
pfrederi 19,936 #5 Posted June 30, 2016 2 hours ago, ronhatch said: M C-101 has a 42" SD deck. I kinda figured that the clutch pulleys were all the same, but I though I would ask anyway. It just seems like all the newer mowers runs there blades a lot faster then our older tractors do. I am not so sure about that. The Consumer Product Safety Commission limited tip speed several years ago ...but long after our older horses were produced Share this post Link to post Share on other sites
daveoman1966 3,882 #6 Posted June 30, 2016 I have a SMALLER 2-belt CENTER deck pulley that MAY suit your needs. It is about 1/2" smaller on the TOP, so all 3 blade spindles would pick up some speed...not sure how much. This iis a NEW pulley and if you want pics and price, send me a direct email...(off forum, that is) This is my email: daveoman@windstream.net Share this post Link to post Share on other sites
