MWR 321 #1 Posted June 28, 2016 I finally found a machine shop that would turn my cranks. He asked me $35.00 to turn one crank, so I took him two. He then said he would turn both of them for $30.00 each. I said OK. He put a micrometer on them and proclaimed that one was wore almost 3 thousands and the other one was wore almost 4 thousands. Now both are 10 thousands under. This is when I pulled the crank, after the rod broke. This is after a few hours in the muratic acid. I buffed them out with a fine grit sanding sponge and they shined up, but they needed more. And this is after having them turned 10 thousands. I'll probably leave them wrapped in this plastic until I get ready to rebuild one of the engines. 5 Share this post Link to post Share on other sites
Wheel-N-It 2,978 #2 Posted June 28, 2016 Keep a coat of grease on them so they don't rust. 4 Share this post Link to post Share on other sites
