Macgyver 109 #1 Posted June 24, 2016 What's the difference between the two decks? Just got a 92 520h I have a 42" SD and the recycle deck is rear discharge but what makes it different? I mean between a Rear discharge and the recycle? Share this post Link to post Share on other sites
AMC RULES 37,210 #2 Posted June 24, 2016 Should be a circular baffle up, under the deck to trap the clippings... and, I think...different/high lift blades. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,512 #3 Posted June 24, 2016 Garry Share this post Link to post Share on other sites
nylyon-(Admin) 7,969 #4 Posted June 24, 2016 Yep, the baffles and wider blades Share this post Link to post Share on other sites
Macgyver 109 #5 Posted June 24, 2016 I looked &down loaded the manual for the recycle deck. If I removed the baffles that are bolted in then I would have a 42" RD deck is that correct? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,512 #6 Posted June 24, 2016 2 hours ago, Macgyver said: I looked &down loaded the manual for the recycle deck. If I removed the baffles that are bolted in then I would have a 42" RD deck is that correct? Correct Garry Share this post Link to post Share on other sites
