geminiguy 0 #1 Posted June 20, 2016 I have C-160, 1-0481. Something inside must have jammed in the bottom of the rear end assy and cracked the housing. Anyone know if this is 'common' and maybe caused by a loose nut ? Which type of rear end would do this ? Thanks, CKain Share this post Link to post Share on other sites
AMC RULES 37,259 #2 Posted June 20, 2016 Once you crack it open, and remove the offending object... you may be able to find a replacement trans case to get you up and running again. Share this post Link to post Share on other sites
daveoman1966 3,884 #3 Posted June 20, 2016 Your C-160 auto has a cast iron gear case (transmission) and can't be repaired if cracked / broken. I have BOTH sides of this available when you decide which is broken / cracked. Here is a pic or two of the Letf and Right sides... I probably can replace any broken internal parts too....gears, bearings, etc. for more info, send me a direct email to this address: daveoman@windstream.net 3 Share this post Link to post Share on other sites
857 horse 2,588 #4 Posted June 20, 2016 Red Square,,,,your one stop repair shop,,,,, Go Dave !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1 Share this post Link to post Share on other sites
Thisguyisnew 114 #5 Posted June 20, 2016 Sorry to jump in but does any one have a proper carb jet for a 16hp 1974 c-160. Had to make temporary one so carb doesn't spew gas but would like to have an original Share this post Link to post Share on other sites
stevasaurus 23,763 #6 Posted June 20, 2016 Thisguyisnew...you need to start a thread in the "Engine Section". Not many will see your post here,. and I don't know the answer. Share this post Link to post Share on other sites
Thisguyisnew 114 #7 Posted June 20, 2016 Thanks. I guess I should have known better really ... 2 Share this post Link to post Share on other sites
mikeeyre74 290 #8 Posted June 21, 2016 This is an Automatic? I have a Unidrive, gear drive, that I have the case to.. you're welcome to it for nothing. Of course, I'm in CT... 1 Share this post Link to post Share on other sites
